driver's seat bolt's
I have what i'm told is a common 306 problem the bolt's have come out from under the driver's seat and arn't in the car ( they wern't in the car when i bought it ) .... can anyone tell me what bolt's i need to get to replace them of if the seat's out of another peugoet will fit because i can't find another 306 seat
i have some spare bolts kicking around, is that all you need? . .Smile
Best to go to a scrappy, then bobs your uncle Smile
(28-04-2016, 03:35 PM)MY95 Wrote: Best to go to a scrappy, then bobs your uncle Smile
Every scrappy i've been to either doesn't have any driver's seat's or they are in a worse state than mine
(28-04-2016, 03:12 PM)Mattcheese31 Wrote: i have some spare bolts kicking around, is that all you need? . .Smile
As far as i know that's all that's wrong m8
Which bolts? Can't say I've come across seat bolts falling out!
If you lean back in the seat does the base move? If so this is what is wrong with the misses seat. Hers is a pita feels like it's lopsided haha
(28-04-2016, 08:21 PM)Toms306 Wrote: Which bolts?  Can't say I've come across seat bolts falling out!
The one's that bolt the seat to the frame
I've never heard of seat bolts coming out and I've had 7 306's lol, bolts are same in passenger seat too you know.
(28-04-2016, 11:39 PM)Matt Wrote: If you lean back in the seat does the base move? If so this is what is wrong with the misses seat. Hers is a pita feels like it's lopsided haha
That's exactly what mine does
I'm on my 15th 306 and not had any seat bolts falling out. lol
The base moving is usually a snapped frame Matt, will need welding up if that's the case. The other common one is the height adjuster not staying set, and the base moving down and back as you accelerate then forward and up as you brake, that's an irritating one haha.
Yeah I'm with Tom on this, won't be the base bolts Smile
Ive had 4 306's and one had loose seat bolts!
Worth checking! I didn't find the 4th bolt till I whipped the seat out.
I'm on 306 number 14 none of mine have had it. My misses buys 1 and it's got it lmao will take a proper look tomorrow
  Patching my driver's seat chylledapps 12 6,249 10-12-2014, 10:48 AM
Last Post: Toms306
  Driver seat issue Nathan1305 2 2,604 09-03-2014, 03:39 PM
Last Post: Nathan1305
  Removing Driver seat Moh 6 3,506 13-01-2014, 09:12 PM
Last Post: Moh
