Removing Driver seat
I was going to take my driver seat out a few days ago but gave up as the front torx is hidden under the seat cowling. Any way around this than to push and shuv my way to the torx.. Also my torx set is like a set of alan keys so maybe i need to invest in new tools.
Small torx bit with a ratchet is the only way I know lol
Take the center console out and undo the torc screws hosting the plastic in. Gives you some flex in the plastic which helps a lot.
+1 small torx and ratchet easy enough
I used torx, ratchet, and a wobble head lol
make sure you replace those little black things the seat sit on on the centre console side otherwise the seat sits kinda scew wiff and doesnt slide back and forth on the rails properly.
going to do do this tomorrow sort and attempt to sort my airbag issue out.. thanks for the advice lads
  driver's seat bolt's Andrew75 12 6,583 29-04-2016, 05:34 PM
Last Post: Matt
  Removing driver's lock Iceman299 7 5,675 19-07-2015, 08:21 PM
Last Post: Redordead89
  Patching my driver's seat chylledapps 12 6,356 10-12-2014, 10:48 AM
Last Post: Toms306
