22-02-2014, 06:32 PM
Got a knocking noise coming from the front nearside area when im accelerating also freewheeling, am i right in thinking it is a cv joint ?
knocking noise
More likely to be a ball joint I would think.
Edit, or P bush
22-02-2014, 07:52 PM
24-02-2014, 11:44 AM
Had the same thing, turned out to be driveshaft
24-02-2014, 08:47 PM
I have the same kinda thing, usually under hard accelerating/braking but it does sometimes happen over potholes etc but I do know from having it out before, that driveshaft definately needs changing so I'm trying that first
01-03-2014, 05:00 PM
Does it knock on braking too. Have someone look when you brake and see if the wheel moves back in the arch. If so id change the wishbone and balljoint with it
Team disASTOR? ![]() |
| Annoying Knocking / Scraping Noise | mspdan | 7 | 4,491 |
31-03-2014, 07:35 PM Last Post: mspdan |
Annoying knocking noise | Bnmtuning | 7 | 4,375 |
01-03-2014, 04:53 PM Last Post: Razorback_Rob |
