27-02-2014, 06:05 PM
![[Image: 8y2y7yvy.jpg]](http://img.tapatalk.com/d/14/02/28/8y2y7yvy.jpg)
Not fully built, just a mock up. Look ten times better
306 Stage 2 HDi Progress/Project.
![]() Not fully built, just a mock up. Look ten times better
27-02-2014, 07:10 PM
Giving me a checklist to put together on my hdi for its stage 2. Wish mine was diablo though
Team disASTOR? ![]()
27-02-2014, 08:29 PM
Lol what colour is it?
Get it sorted, stage 2 is good fun! Such a different car compared to stage 1 & stabdard.
28-02-2014, 06:42 PM
The adjusters on my coilovers were so bad in the end i had to cut them off!
Dont suppose either of you fellas have a spare set?
28-02-2014, 08:09 PM
No man, ive only these ones here.
Got the coilovers in today, but as expected the pinch bolts were siezed solid. So out came the hubs, and into the vice. ![]() All sorted now, although as expected its not perfect. Drive shaft roller bearings collapsed and went everywhere, put as many as I could in and put it altogether and there is what I can only describe as a violent pulling feeling through the transmission. So it wont be drove until I get a replacement, I had bother with this before so I may just get a new driveshaft. Another little problem was one of the abs sensors being a stubborn shit as usual and broke on me, but got the other one out fine. So I now need a driveshaft, and an abs sensor. ![]() Not too low yet due to the boost pipe arrangement (under the crossmember) Replaced the reverse switch today aswell
28-02-2014, 08:31 PM
Looking really good mate can't wait to go stage 2. I had them roller bears I had the same problem I lost 3 of them thought it would be alright a few days later it seized up completely they are cheap enough from eBay brand new for a shaft.
Bye Bye D-Turbo
Phase 1 GTi-6 now has a new owner Rolling in the: Phase 3 HDI Wagon The current estate project: http://306oc.co.uk/forum/thread-22237.html
28-02-2014, 08:57 PM
Cheers man!
Yeah its good stage 2, I want stage 3 now lol! Crazy what the power bug does to you lol! Yeah might just grt a new one and hopefully not have to worry about it again for the time I have the car!
28-02-2014, 10:14 PM
Get the pipes sorted and get lower
lol will look well when the backs done aswell bad luck about the driveshaft and sensor though
28-02-2014, 11:38 PM
Some great work going on here. keep it up pal.
28-02-2014, 11:55 PM
(28-02-2014, 10:14 PM)E_KEL95 Wrote: Get the pipes sorted and get lower Haha ill see what way it settles in, hasnt been drove and god knows if theres been weight on them springs this last while. (28-02-2014, 11:38 PM)SRowell Wrote: Some great work going on here. keep it up pal. Thanks bud, have looked to your project for inspiration on occasion lol! Hopefully start getting stuck into cosmetic jobs on the car with the weather getting better as the hardware is getting to a standard im happy with.
01-03-2014, 12:09 AM
(28-02-2014, 11:55 PM)mcglynn Wrote: Haha ill see what way it settles in, hasnt been drove and god knows if theres been weight on them springs this last while. What ya tryna say? Shit one about the shaft but as said she will look well lowered
01-03-2014, 12:12 AM
Were they just fresh outta your car or had they been lying a while basically...
If they were just outta it then theyll not need time to settle I wouldnt think, if they were out a while then the springs might have lengthened ue to no tension on them and they may well settle lower than ive it set just ![]() Yeah gonna get one tomorrow and see if its it, if that solves it ill be putting a new one in next month if the one the mate has lasts.
01-03-2014, 12:23 AM
The were fresh out of mine lol albeit a lot lower. Looks like I might need a shaft too
01-03-2014, 01:32 AM
Ah, well theyll not settle much lower then.
Will have to start parking in the street my driveway is hectic, two dips and a big rise in the middle, like a greenlane..
01-03-2014, 10:07 AM
Shafts are cheap enough from http://www.jandrcvjoints.co.uk/driveshaf...red&page=7
All sorted, decided to approach it with patience today.
I took apart a the needle bearing on an old shaft, cleaned everything up and covered it in grease. Then proceeded to filling up the needles and pushed on the outer bearing. Cleaned the inner cup/cv joint, where i found loads of needles and packed it with grease and rebuilt. Cars sorted snd driving fine, crying out for the vibratechnics engine mount since everything else is done now! Should tighten it all lovely.
04-03-2014, 06:37 PM
![]() New present for the car, hipefully solves my rocking horse engine.
04-03-2014, 09:42 PM
They're not as bad as everyone makes them out to be, thats all im saying :p
04-03-2014, 09:44 PM
Yeah man everyone goes on about paddle clutches being so bad etcetc but ive drove mine for about 2 or 3 k now and its fine
wouldny cause me to complain.Anything will be better than the engine rocking back & forth under acceleration and deceleration
05-03-2014, 04:31 PM
![]() Some more progress, old ones werent actually bad.. so not much difference (I dont think? What should I be noticing?) Glad theyre finally in though, next up is engine mount, probably be friday before I get it in!
05-03-2014, 07:52 PM
Which way did you put the bearing in with the top mount and your coilovers?
05-03-2014, 09:17 PM
Ohhh, same way they came out of my old top mounts.
The curved side down into the coilovers, and the other sidee up into the top mount. The bearing looks like it sits 'awkwardly' into the top cups as you build the coilovers up, but I have no notchiness in the steering and no odd noises so it must be ok.
05-03-2014, 09:46 PM
(05-03-2014, 04:31 PM)mcglynn Wrote: The front bush on the wishbone is usually ok. Its the P bush that is prone to failing and it makes the car feel like it has 4 wheel steering! I had powerflex in mine since i bought the car 7 years ago and they are still fine.
06-03-2014, 01:27 AM
Yrah powerflex bushes come with a lifetime guarantee, so should be fine still.
One of my front ones was worn, after driving the car a bit more tonight it seems to have made the front less 'divey' into corners. As such, it seems to hold a steady line a lot easier, bearing in mind my p bushes (2 or 3 months old) are fubard, so will be getting those replaced under warranty and the rear engine mount and it should really tie it all together and make the front end handle better!
06-03-2014, 11:59 PM
Haha and interior, and boot trim, and steering wheel. Lol all donations accepted
07-03-2014, 06:58 AM
I'd suggest getting powerflex p-bushes tbh bud, they come with 0.5 degrees of camber already dialled in and make a huge difference to how the front end feels, takes all the slop out of the bush assembly. If the current ones have only lasted 3 months i shouldn't think the replacement set will fair any better.
Did you have to shave the back of your round bushes (giggidy) or have they changed the design so they fit properly? (07-03-2014, 06:58 AM)Poodle Wrote: I'd suggest getting powerflex p-bushes tbh bud, they come with 0.5 degrees of camber already dialled in and make a huge difference to how the front end feels, takes all the slop out of the bush assembly. If the current ones have only lasted 3 months i shouldn't think the replacement set will fair any better. Theres a thread I started about these... Dont mean to gloat but that new design is due to me sending a LOT of emails, photos dimensions etc and weeks of working with Powerflex to redesign those front bushes...should find they fit wonderfully easy now, compared to an absolute bitch or needing to cut them. If you have the old design email Pflex and they will send you the updated design. And if you cant afford powerflex P bushes, get the late berlingo ones...100x better than the 306 sloppy design Oh and for your engine cover, try these: http://pages.ebay.com/link/?nav=item.vie...1074371561 Wishes for more power...
07-03-2014, 12:03 PM
(07-03-2014, 06:58 AM)Poodle Wrote: I'd suggest getting powerflex p-bushes tbh bud, they come with 0.5 degrees of camber already dialled in and make a huge difference to how the front end feels, takes all the slop out of the bush assembly. If the current ones have only lasted 3 months i shouldn't think the replacement set will fair any better. Yeah bud these are the updated ones, they fit in nice and flush and squeeze into the subframe nicely! I also have the old ones here and they would have been a nightmare... The p bushes I fitted are the peugeot partner ones (nice solid looking ones) but I think the premature failure is partly to do with my engine mount being done, aswell as the angle I had them fitted at being off perhaps. My rash driving probably tipped them over the edge too. With all other bushes replaced bar those p bushes, I should think a new set at the right angle will last a bit longer. I will soon see though, fingers crossed (07-03-2014, 07:49 AM)Piggy Wrote:(07-03-2014, 06:58 AM)Poodle Wrote: I'd suggest getting powerflex p-bushes tbh bud, they come with 0.5 degrees of camber already dialled in and make a huge difference to how the front end feels, takes all the slop out of the bush assembly. If the current ones have only lasted 3 months i shouldn't think the replacement set will fair any better. My engine cover is on bud, I have m6 threaded bar, nuts, washers and wingnuts. Id recommend it aswell as your idea, as mine doesnt rattle off anything or vibrate ![]() And already have both the new front wishbone bushes from powerflex (thanks for the info on them, they've made my lift a lot easier) and the berlingo/partner p bushes. Hoping as said they last a lot longer this time round. (07-03-2014, 09:41 AM)Midnightclub Wrote: FYI it's castor they add, not camberHaha I wouldn't know, powerflex ones are out of my budget for now lol
| My Nile 6' Project/Progress (New zorst vid pg.9) | Midnightclub | 329 | 258,359 |
19-08-2017, 08:13 AM Last Post: Midnightclub |
| Matts Cherry HDi Dturbo. Project Stage 1+ & tidy up. | Matt-Rallye | 29 | 25,985 |
10-05-2017, 12:49 PM Last Post: Poodle |
| Small progress... | laurence_13 | 23 | 19,503 |
10-11-2016, 05:14 PM Last Post: 1616six |
