Wanted | Heater Matrix hoses
After a set of heater matrix hoses that go into the bulkhead
From an 02 plate hdi
They look different to any I have lying around, the pipes come out at an angle to clear the brake servo, and also it doesn't have a long pipe for bleeding, it just bleeds at the union itself.
Do you have a pic of yours?
Bianca Rallye
1989 205 GTi6 on ITBs
BMW Z4 3.0
Thousands of GTi6 parts availabile.
How desperate are you for them we are fitting jimbos xud on the 8th and swapping the ones from that to the xud ones
I might be able to get a pic of bits of it, could do with it asap as usual Smile
The plastic bit that goes into the bulkhead does look like this one
How the pipes then go doesn't really matter too much as can make something up
[Image: 003.jpg]
I'll get a photo of a set I have this evening. The angle is the same from memory - but has the bleed point on a length of hose. May be compatible.
Bianca Rallye
BMW Z4 3.0
Sweet cheers!
My hdi ones where like that. So should be easy to get
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
bump - anyone got a set they can post out or collection near Birmingham?
Pic of the one I have:
[Image: image_zpsd986bd01.jpg]
Bianca Rallye
BMW Z4 3.0
Ive got one here. think its missing the bleed cap though, might have a spare i can pop on but ill need to have a hunt for it.
Despite being a later shell, its having an xud transplant
The two pipes - one goes to the back of the block, the other to the back of the head - so as long as they're long enough to reach that far it'll be fine.
(02-03-2014, 10:23 AM)Dangti6 Wrote: Pic of the one I have:
Those will probably be fine - held in by one metal clip through the centre of the hoses? rather than the older style which had a plate that screw over + a metal clip round the outside?
(02-03-2014, 10:37 AM)PE02KHG Wrote: Ive got one here. think its missing the bleed cap though, might have a spare i can pop on but ill need to have a hunt for it.
I can find a bleed cap no worries Smile
£5 plus postage? I'll try and get it sent tomorrow.
Just pop me a pm if you want it
  Wanted: heater matrix hose for my 97 Xsi 16v kimber72 1 2,942 23-05-2020, 02:32 PM
Last Post: Mighty306
  Wanted: Xsi heater matrix hose rydon 0 2,280 11-07-2019, 07:41 PM
Last Post: rydon
  Wanted: SUPER URGENT: 1.8 Heater Matrix Pipe Eeyore 3 3,263 11-05-2015, 09:10 PM
