Wanted: SUPER URGENT: 1.8 Heater Matrix Pipe
Hi All,
Replacing the heater matrix on the 1.8 and pulled a bit too hard and snapped the plastic end bit. Amazingly the next tug and it came off fine...
So im looking for a 1.8 or xsi or (perhaps gti although ive heard there are differences) heater matrix pipe.
What have you got? Should look like this. Although this is a gti one and seems to have an extra bit of pipe on the plastic bit...
[Image: %24_57.JPG]
Sam
if you have a gti manifold you do need the gti pipework as it sits higher up the bulkhead however the routing in the engine bay is a little different IIRC
(11-05-2015, 07:37 PM)welshpug Wrote: if you have a gti manifold you do need the gti pipework as it sits higher up the bulkhead however the routing in the engine bay is a little different IIRC
Ah so I have a standard 1.8 manifold however I will be fitting the GTI6 Manifold shortly so I need the gti6 one dont i?
Should have this sorted now as Im going to see Carl Chambers tomorrow.
  Wanted: Heater Radiator Pipe Hose for 2.0 XU Engine Dowranj 0 2,577 15-09-2020, 05:12 PM
Last Post: Dowranj
  Wanted: heater matrix hose for my 97 Xsi 16v kimber72 1 3,167 23-05-2020, 02:32 PM
Last Post: Mighty306
  Wanted: Xsi heater matrix hose rydon 0 2,422 11-07-2019, 07:41 PM
Last Post: rydon
