13-02-2014, 12:48 PM
moved at OP's request . . . .
Bianca xud GT20
06-03-2014, 10:02 PM
so, removed the engine for a donor lump but got let down, so decided to paint and do a few things to my engine, so it had a new timing belt, waterpump MLS headgasket, headbolts, ngk glowplugs, oil and filter, and a repaint.
![]() couldn't be botherd to paint the starter/alt, kinda wish I did though. got an oil feed made for the gt20. ![]() ![]() decided to paint the engine bay, it needed it. ![]() engine going back in. ![]() and in ![]() ![]() ![]() finished and a wash. ![]() then decided to make an air feed for the gt20. ![]() my first ever engine change, borrowed a crane from a mate and me and my stepdad got on it, did it slowly and when we could be bothered, tax had run out anyway so wasent in a rush, taxed for 6 months now and also transferred my private plates over. got the gt boosting 19psi, as the pump needs more tweeks, using a td04 actuator atm, could do with an MBC and more fuel, also, speedo has stopped working and ive somehow got a winey tensioner or something.
06-03-2014, 10:05 PM
Yes! Epic epic car now. Look forward to seeing your awesome in car videos, and more tuning and all that awesome shit. As i keep saying on facebook mate, good work
06-03-2014, 10:34 PM
Looking sweet but gonna say ph1 or full ph 3 it
![]() the smokey old bus that sounds like a tractor...
06-03-2014, 11:46 PM
Looks top notch bud, makes me itch to get mine done!!
Keep us all posted with how it goes, videos much appreciated
07-03-2014, 12:02 AM
looks ace bud...you must be pleased??
dopes she pull well even at 19psi?? and to be honest, 24/25psi is right at top of whats worth pushing with that gt20 Wishes for more power...
07-03-2014, 12:07 AM
hmm, 19psi, im not sure, was expecting more, and its laggier than I was expeting, feels more T2 in terms of spool.
07-03-2014, 12:17 AM
(07-03-2014, 12:07 AM)padge Wrote: hmm, 19psi, im not sure, was expecting more, and its laggier than I was expeting, feels more T2 in terms of spool. theres more to give, just dont go thinking 30psi is win. May need some more setting up, but being like a T2 to spool isnt a bad thing when you consider how it blows Wishes for more power...
07-03-2014, 12:25 AM
(07-03-2014, 12:19 AM)padge Wrote: im aiming for 25psi max so will see how it goes. yeah thats a fair wack, they begin to leave their efficiency zone after that and just make for heat. remember, its already doing a better job at 19psi than a td04 at 30psi Wishes for more power...
07-03-2014, 10:09 AM
What's the smoke situation like? you said the pump needs tweaking, does it coal much? may need some more to wake the blower up. are you running a 9mm or?
Nice work though! See FB snippets, glad to see you've put it all together though!
07-03-2014, 11:33 AM
Looking good mate.
Think a TD05 would of sutied you more.
07-03-2014, 11:49 AM
Wait the turbos on! Never thought I would see the day
![]() Looks good lad
07-03-2014, 01:09 PM
07-03-2014, 01:14 PM
Haha when are you expecting spool up? Sub 2k is where its at
07-03-2014, 01:15 PM
07-03-2014, 02:08 PM
(07-03-2014, 11:49 AM)Danny2009 Wrote: Wait the turbos on! Never thought I would see the day Good work with it all as said get more Fuel in there sure it should wake that turbo up then
07-03-2014, 03:19 PM
(07-03-2014, 01:50 PM)padge Wrote: I reckon if i chuck some more fuel in. It will liven it up abit. Too right, my gt2056s is at full chat by 2000rpm, thats at 24psi. its on 11mm mind. and does smoke heavy if you mash it in obviously. sounds like she wants some more fuel, maybe a little advance too? Wishes for more power...
07-03-2014, 04:13 PM
Shes running a bit of advance as it is, dont want to really go anymore, you using an mbc piggy?
07-03-2014, 05:26 PM
no, using the standard waste gate arm.
going to need a stronger spring soon though, as it wont hold anymore than 24psi Wishes for more power...
07-03-2014, 09:17 PM
Really glad you stuck at it mate! Top work!
14-03-2014, 07:45 PM
Looks really nice though mate!! Get a vid of the whine im sure we can work it out :p
14-03-2014, 07:46 PM
no whine when its cold, only does it after 10 mins or so of driving, also, only whines on idle.
should spray the underside of the bonnet bud, would look a lot fresher!
could be timing belt too tight? i know when we fitted my hdi belt first time round it whined like s supercharger, was too tight on the timing belt |
| Garrett GT20 Project | 306Puggy | 179 | 148,047 |
22-10-2013, 06:56 AM Last Post: Scott |
