ever since I got it, its used water, and its gradually got worse, also, with the rad cap on it pressures up, and its now started going to 95c, and the heaters go cold, it did this last time when the thermostat died, so I put a new one in and it sorted it, but I have to top the rad up every 2-3 days with a kettle full of water..
Bianca xud GT20
05-02-2014, 08:13 PM
Head gasket ?
05-02-2014, 08:14 PM
sounds like it ted, why else would it pressure up?? its had a brand new matrix too, so cant be that, temps almost always 95c.
05-02-2014, 08:17 PM
Been worse since the GT20 fitted?
Peugeot 206 GTI HDI
Volvo V50 2.0d Volvo XC90 D5
05-02-2014, 08:20 PM
Could be a crack in head
05-02-2014, 09:12 PM
The gt20 will defo finish it off that's for sure if you fit it that is, get headgasket done first
and arp headstuds why your at it
05-02-2014, 09:16 PM
f*ck ARP headstuds, I know one or two people running a gt20, with normal headbolts
05-02-2014, 09:21 PM
I cant remember who it was, but its someone on here for deffo, seen them say there using normal valeo and normal headbolts.
05-02-2014, 09:22 PM
Hmmm not sure who that is then.
Peugeot 206 GTI HDI
think it was ricky?
also did chris with the estate and 2056 run arp or not?
05-02-2014, 09:28 PM
Ahhh yeah I think so actually. But afaik it was only ever running low boost and possibly not set up right.
Peugeot 206 GTI HDI
05-02-2014, 09:46 PM
think he got it running 25psi, he tried at 30 for a few times but the turbo kept popping, ill be happy with 25psi tbh.
Im running gt2056 with std studs n valeo...
1.5bar n only issue is turbo flutter from crappy standard inlet/exhaust mani n head...been at that for a good 4k N yea, sounds like HG Wishes for more power...
06-02-2014, 07:14 PM
Parts cost though, anyway..
Removed thermostat and put the rad cap back on, and it runs fine now, no pressure or high temp, put the 5 week old thermostat in some boiling water and it did nothing! so looks like new thermostat is needed.
06-02-2014, 08:16 PM
Hahahaha piece of shit!! Thats a good result to be fair
06-02-2014, 08:33 PM
Yeah, im still gathering bits for a rebuild though
this months going to be hard, need to pay for my plate swapping over, and tax too, nevermind!
10-02-2014, 06:05 PM
Well put a new thermostat in and rad cap back on and it goes straight to 90-95c cold heaters and pressures up..
10-02-2014, 06:17 PM
Thermostat out again then! They sell 12v heaters at halfords!
| Garrett GT20 Project | 306Puggy | 179 | 148,080 |
22-10-2013, 06:56 AM Last Post: Scott |
![[Image: Untitled-1_zpsc57da38e.jpg]](http://i112.photobucket.com/albums/n180/w1n_2006/Untitled-1_zpsc57da38e.jpg)
![[Image: fe6eddc8-1731-4100-a5fe-1edb853a88b6_zpseeacf928.jpg]](http://i1236.photobucket.com/albums/ff441/big543/fe6eddc8-1731-4100-a5fe-1edb853a88b6_zpseeacf928.jpg)
![[Image: image_zps45f2003b.jpg]](http://i39.photobucket.com/albums/e174/austinmini-2008/image_zps45f2003b.jpg)
