JIMBOS ph3 xud Rolling road results
Yeah, next weekend I reckon rip engine out of red one, get headgasket done. Then mock turbo up and downpipe.
Wack on the.bosch then get it in the Hdi.
Cant wait tbh
Ahh and get an oil feed made up.
Gotta ask mr.fish were he got his done
[Image: av5ym8.jpg]
#32
Need to say about the good news on axle Smile
#33
Oh yeah, so my old axle off my black dt has been up frostys for best part of a year. Decided to get it home and take apart.
Turns out to be a really good axle
Plenty of grease in there no wear on bearings or trailing arm pins.
So what im doing now is using this tube
Going press pins out of drum trailing arms and put them in my disc onea and build up with new seals etc. Put my 21mm '6 Torsion bars in and a 24mm ARB..
Using new offset washers,screws seals and caps etc. She should be good for a while Wink
Ill get some pics tomoro nite
[Image: av5ym8.jpg]
#34
Slight update (nothing amazing)
Have had a load of parts turn up ready for when the engines out.
Bosch lines
Bosch injectors
Still waitin for pump
Victor reinz headset, head bolts and headgasket
And the turbo
Garrett gt1752s
Not massive but I didnt want sill power.
So should be a comfortable 150 bhp hopefully
And its fair bigger than a t2 and being a gt series its more modern design
Currently making adaptors etc
The standard oil line fits though Wink
And the main reason is there cheap and plenyful.
[Image: DSC_0140.jpg]
[Image: DSC_0141.jpg]
[Image: av5ym8.jpg]
#35
A few shiny bits there will make that turbo plate tomoro then get the bugger bolted up this is the t2 with the gt17
#36
Yeah cheers for pic mike, clearly see the difference in compressor housings there,
Also forgot to mention that we've had to modify the actuator bracket and am gonna use a t2 actuator.
Not that anyones seems to.comment on these updates :/
[Image: av5ym8.jpg]
#37
Stop moaning Wink That comp housing looks quite a bit bigger on the GT17 :p
Yep it's fair bit bigger and the hot side not massive so I would say it should spool up pretty well and as this is all going in a phase 3 will be win
#39
Yeah she reet, hopefully spool up fast and pull through to 5k should keep me happy and most of all be reliable.
If its anything like frostys k03 ill be happy chappy
Out of interest tom what does your td04 spool at 2.5,2.75k?
[Image: av5ym8.jpg]
#40
Looks like some good progress, bet you can't wait to get it all together
#41
Cheers mate, yeah its been too long without an xud.
Should start coming together over next few weeks with some "proper" progress updates
Were thinking of dropping engine out this sat Wink
[Image: av5ym8.jpg]
#42
Yeah about 2.5k i start making boost, i generally go with if im past 3k i can matt the pedal and go for it!
Fair enough, im hoping around 2.25k maybe but as ruan said in another post the 1752 as soon as it starts spooling.to max boost is almost instant. However comes in a bit later than say a 2052/6 etc.
[Image: av5ym8.jpg]
#44
This is an interesting thread!! Should be a nice well rounded package....
JP
#45
Should be a nice little spooler Smile
#46
Cheers guys, hopefully it all goes in easy enough
[Image: av5ym8.jpg]
#47
what does the exhaust side look like? are you making a bigger downpipe?
if it was going in a ph1 then it would be total win Tongue
Sounds like its going to be in sooner than expected?? Smile
#48
Bit more progress made this week,the turbo is finished/mounted apart from a downpipe that will be made when its on the car, actuator fitted and oil line all still fits, we welded the plate to the turbo using dissimilar metal arc rods which is only way to weld cast properly. 20 quid for ten rods, not cheap but no its gonna hold and not crack etc.
[Image: IMG-20140109-WA0002.jpg]
[Image: DSC_0152.jpg]
[Image: DSC_0149.jpg]
Also my bosch turned up, so pulled top off to have a look inside and gov mod it, looks clean in there though pretty dry hoping it runs ok and few vanes arent stuck. Also wacked in a ground lda pin I made
[Image: DSC_0154.jpg]
[Image: DSC_0155.jpg]
[Image: DSC_0156.jpg]
[Image: av5ym8.jpg]
#49
Nice pic of me doing a good job of holding the engine will have to fill that pump with fuel hope to get the engine out later
#50
With a bit of luck yeah. Frostys coming over to give a hand.
[Image: av5ym8.jpg]
#51
Wait so a gt20 comes on blow before a gt17? Well my turbo education is shot.
My turbo is off a petrol car, slightly larger hotside
It may come in real early but I cant say tbh till I drive it
[Image: av5ym8.jpg]
#53
Makes sense. I was just going off a "its smaller must spool faster" knowledge.
hotside looks exactly the same as my gt20, had to cut mine down big time.
#55
My turbo is near on exact same lenght etc as the t2 Wink
[Image: av5ym8.jpg]
#56
mine isn't lol.
#57
Yours being off a merc would be longer due to it being down side of engine, theres loads of room on the merc.
Does the downpipe have a vband clamp
[Image: av5ym8.jpg]
#58
it just looks the same as yours on the back of the engine.
#59
Right on, another update starting to move along now
Engine is out of the red car, me mikey b and Frosty took it out last weekend in minus 1 degrees like real men in the dark, few crap pics but dragged engine subframe and front suspension out in one. Few crap pics
[Image: DSC_0160.jpg]
[Image: DSC_0163.jpg]
So then got engine back to my garage, I had my bosch to test after having it apart, also Mike wanted to test his 11mm. Had engine on floor not tied down at all just on crane, 5ltr Jerry can and run the engine like that.
Fair to say Mike's11mm created fair coal
[Image: IMG-20140117-WA0004.jpg]
Anyway stripped engine down later that week, ready to paint block build head etc replace gaskets whilst its apart.
Turbo is ready to go. So its a case of put engine together again and fit it finally, I cant wait.
[Image: IMG-20140119-WA0002.jpg]
[Image: av5ym8.jpg]
#60
Yep me 11 mm pretty smokey lol you forgot to say that you finished of the down pipe today
  Jimbos PH1 kingfisher Dturbo ☆turbo progress☆ Jimbo 122 73,613 22-08-2015, 04:59 PM
Last Post: mr_fish
  Jimbo's 51' white HDI estate ROLLING ROAD RESULT Jimbo 84 46,335 28-05-2015, 05:32 PM
Last Post: Jimbo
  Sigma 5dr 1.9 XUD Project Dyno Results Included c.gerrard 195 121,478 02-02-2014, 11:43 PM
Last Post: devils_fuel
