dump valve leaking oil
tim, just put up a wanted ad...bet theres loads stuck in boxes in sheds of loads of us here
cheers kyle Smile
You dont need to get under one you can do it all from the top shouldn't be a big job at all max 30mins as it can be fiddly.
Dump valve is off and a mate has capped the T pipe for me just need to buy a turbo for it now anyone no who's selling one cheap as poss
(30-12-2013, 04:45 PM)DTurboTom Wrote: Dump valve is off and a mate has capped the T pipe for me just need to buy a turbo for it now anyone no who's selling one cheap as poss
Might not need to buy new turbo if it's only a small amount of oil.
yeah, may just be breather system, you be amazed how much oil and residue is inside all the pipework even on a perfectly good turbo.
Who knows how long that dumpboostvalve has been leaking like that.
Is it dropping boost or whinning?
not boost and yeah it winns lol
I used a piece of pvc plumbing pipe to join back the tmic.
That may not be excessive depending how long it has been building up for.
Either way remove the dv as yours will just be causing a major boost leak as the spring isn't strong enough to resist the boost pressure
HDi Cabby Project Click
dump valves off mate just need a new turbo
Get a td04 on it Wink men as well upgrade now why your at it Big Grin
Will I need any fittings or will that just go straight on
(30-12-2013, 11:41 PM)DTurboTom Wrote: Will I need any fittings or will that just go straight on
There's no upgrades that just bolt on, unless some one else has done the work for a bolt on upgrade.
  Dump valve on a diesel? 306pc 14 7,245 29-07-2014, 04:34 PM
Last Post: ADV_93
  Oil leaking from EGR valve HDIkyle 0 1,627 29-01-2014, 02:25 PM
Last Post: HDIkyle
  fitted a dump valve now lossing boost ingham66 uk 9 5,111 15-06-2013, 11:23 AM
Last Post: Piggy
