Oil leaking from EGR valve
Noticed today there is oil pouring down the back of the engine. Checked rocker cover gasket, its fine. Noticed fresh wet oil coming out of the top of the inside of the EGR valve.
The pipe that goes from that to the solenoid is broke, could this be causing the problem with the valve not having a vacuum?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
  dump valve leaking oil DTurboTom 41 19,402 31-12-2013, 08:40 AM
Last Post: Chris_90
