Lambda sensor location
Going to fit a Lambda sensor to my 205, is there any specific place it needs to be or can i just put it where ever is fits? dose it matter if its 150mm from the turbo?
Most cars are at the bottom of the downpipe before the cat or halfway down the downpipe. Not sure if it being close to the turbo and thebheat effecting the reading.
Should be after the collector puts all the pipes into one but as close to that as possible so on the down pipe is ideal.
Iv been doing some research, probably should have done that first but anyway i found this if anyone else needs to fit one
http://wbo2.com/lsu/lsuinstal.pdf
  GTi 6 Lambda Fault Toms306 24 11,605 30-04-2016, 06:09 PM
Last Post: Toms306
  lambda sensor willJspears 5 2,717 02-04-2014, 08:55 PM
Last Post: eddy_gti6
  Rallye lambda sensor, eml light? Mitch 4 2,805 21-06-2013, 06:54 PM
Last Post: Mitch
