Rallye lambda sensor, eml light?
My rallye has an aftermarket exhaust system fitted, from the manifold back, there is no lambda sensor fitted in the system at all, the plug is just lying loose by the bulkhead! was wondering if the eml light should be on? as it isnt and never has been? i tried to read the fault codes at work but our diag wont read it! surely the light would be on if there was no signal from the lambda?! Smile
Blaze '6 and Blaze D-turbo!
Not all the time no, the systems on these cars are still basic compared with modern stuff
I thought the lamda was important?
They can bring up a EML. Normally only if there is one connected and it goes well out of range. If you just unplug it, i think it takes its info from the TPS which is obviously no where near accurate.
Ahh I understand now, cheers guys, wanting to put the car back to original with it been what it is, so will have a lambda plugged in sooner or later! Smile
  GTi 6 Lambda Fault Toms306 24 12,138 30-04-2016, 06:09 PM
Last Post: Toms306
  lambda sensor willJspears 5 2,871 02-04-2014, 08:55 PM
Last Post: eddy_gti6
  Lambda sensor location Daniel306 3 2,879 18-12-2013, 04:00 PM
Last Post: Daniel306
