The sump plug mystery?
Why do the hdi's have two sump plugs, one otop of the other? No one seems to know? Iv heard some crap theory's but nothing solid?..........anyone?
Don't know for sure but I always assumed it was for a sensor that was used on other cars with that sump, oil temp or something.
What he said to be fair.. more than likely for oil temp
i could tell you but id have to kill you cause its a secret!
If it's the same sump as the XSI/'6 its for the oil temp sensor
the 2.1 sump has three Undecided
Iv never seen any psa sump with a sensor located there though. I dunno. Possibly the designer dropped a bollock and realised he could only drain half the oil so added a lower one as a last ditch attempt . Tbf the blank for a sensor explanation seems more viable though.
so you can pick which angle to drain your oil at . . .ThumbsUp
I think there is a set volume of oil left if you have the car perfectly flat (ie on a ramp) and drain from the top one too.
Might be a mad suggestion but, is it a breather plug?
I always take the filler cap of for a breather when i drain one out
Good point. Lol
  Swapping 3 plug to 1 plug bashbarnard 6 5,054 25-02-2017, 05:16 PM
Last Post: bashbarnard
  "mystery misfire" Magenta Sunset 12 6,294 06-10-2015, 10:02 AM
Last Post: Magenta Sunset
  Sump oil temp plug pugdan95 8 6,306 08-11-2014, 09:14 PM
Last Post: pugdan95
