injector leak??
injector leak??
I think I have an injector leaking from itself...
hope pics show:
Ive change leakoff pipes twice thinking it was those but it seems to be coming from around that flange/edge...
thoughts??
what leakoff pipe did you use? I;ve found nearly everything in the aftermarket pretty crap as its all 3.2mm, you need 3mm.
Take the injector out, split it in half clean up the threads then torque it back together.
The injector looks very clean, has it been rebuilt recently? Sometimes they don't reseal properly between the top part and holder. I had one that was leaking after a rebuild, I just nipped the top part up a little more in the holder and it seems to have stopped, although I suspect that's not the recommended way of doing it.
'95 Peugeot 405 GLX with XU10J4RS and ITB's
'97 Peugeot 406 1.9TD with TD04
'05 RenaultSport 182 Cup
(02-12-2013, 01:07 PM)Tom Wrote: Take the injector out, split it in half clean up the threads then torque it back together.
righto...
will try that.
Although my vice is bust so I may try holding bottom half and nipping top half in place....
or just getting a set refurbed properly as they are mega loud
Im looking at refurbing a set myself, its just nozzles are like 80quid for the set lol
exactly...theres some refurbed ones on here for sale...
if I sell some bits or me big turbo I will buy them straight away
You may need to lap the two halves together again, sounds like they're just not sealing together properly, had this issue myself but couldn't be arsed sorting it
(02-12-2013, 03:57 PM)Dave Wrote: You may need to lap the two halves together again, sounds like they're just not sealing together properly, had this issue myself but couldn't be arsed sorting it
Correct, the two mating faces should be lapped, although I didn't bother on mine (but then one did leak). This guide is pretty good:
http://vincewaldon.com/index.php?option=...&Itemid=26
I just cleaned the existing nozzles up and they turned out ok.
(02-12-2013, 01:06 PM)welshpug Wrote: what leakoff pipe did you use? I;ve found nearly everything in the aftermarket pretty crap as its all 3.2mm, you need 3mm.
I cant find 3mm anywhere!?
Refurbed injectors on the way anyway but wana do leak off pipe again...
peugeot/citroen do 3mm.
ta welshpug.
my nearest is 25miles away...but may drop by on way to mates this weekend
  Injector leak doogle-d turbo 8 3,454 07-09-2014, 11:48 AM
Last Post: rikky
  Injector leak off hose devils_fuel 33 12,006 28-03-2014, 10:18 PM
Last Post: devils_fuel
  Leak of Pipe Air Leak PaddyPug 5 5,176 18-09-2013, 08:31 AM
Last Post: PaddyPug
