18-11-2013, 03:13 PM
Joey the VNT boosted 205!
18-11-2013, 03:18 PM
Are you running a billet one at the moment then?
![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
18-11-2013, 03:25 PM
I got a standard rubber one in the bottom and apparently a solid fork bush. So this should tighten it up nicely
18-11-2013, 03:27 PM
It will be horrific with the solid fork bush.
I had billet in both, on my XSI and i hated it. The mrs loved it however ![]() Both is too much IMO. I could only make an un-educated guess as to what it would be like on a derv. But at a stab, worse than a perf? ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
19-11-2013, 05:16 PM
Back to losing water at a much more reasonable rate!
A rad looks exactly how you imagine but I took pictures of the nifty slimline fitting kit :p
20-11-2013, 01:55 PM
Usually use cable ties myself.. For everything..
20-11-2013, 03:38 PM
I think that exhaust looks good
Sounds good to
thanks bud x![]() This weird little thing broke of yesterday whilst changing the rad. Apparently its some kind of earth point. Commonly break on the 205's so I just cut it off and put ring terminals on there and covered them in grease, all sorted now.
21-11-2013, 04:15 PM
Right did something stupid today... and i washed the car.
![]() Wait for it... ![]() ![]() Yep inside the car. Dont worry its only temporary til i get a longer length of fuel hose. But i got impatient. Also have a transit pump on the way for making awesomeness.
21-11-2013, 04:20 PM
Epic!
wonder if it will make much difference with veg oil going though the car not under it.
21-11-2013, 04:22 PM
You can see why the car doesnt like it, i have been driving for about 45minutes before i put that pipe in and i fired it up and the pipe went proper cold with the fuel going through it :/
21-11-2013, 06:02 PM
Notice a difference with the fuel banjo ;P
I found it made a massive difference on mine
21-11-2013, 06:27 PM
I'm going for a drive this evening, hoping for some 3rd gear wheelspin aha
21-11-2013, 06:39 PM
What have you done along the lines with the primer and the fuel filter? As they are still at stock diameter.
Stage 2 XUD Sedan
21-11-2013, 06:42 PM
I dont have a primer nor a fuel filter... Im just having some fun atm. Like i said i got impatient and just stuck it on! I have a primer on the way, but fuel filter im a but stuck with, trying to find a landy fuel filter housing (for a reasonable price) that i can mount either in the bay or under the car with a big spin on filter.
21-11-2013, 06:44 PM
Ah fair one. Be careful running it de filtered! The cars 22 years old and that tank isn't going to be clean!
Stage 2 XUD Sedan
21-11-2013, 06:47 PM
Im running mostly unused or 1micron filtered veg atm so not overly worried about it, i had a check over the strainer aswell before i done it and that was clean as a whistle and alot finer than the one in a 306!
And i guess if the pump does die i'll have to repair it from bits of this transit one i have here...
21-11-2013, 06:52 PM
Why don't you go for the filteriI've got?
21-11-2013, 06:55 PM
(21-11-2013, 06:52 PM)Paul_13 Wrote: Why don't you go for the filteriI've got? Because i read the small print and it says its 120micron and IMO its not worth having. Most oem filters are around 5 micron. Like i said above i filter my veg down to 1 micron cold, so 120 is about enough to catch chips with lol!
Already got a TT filter. Not big enough.
Wake up Chris ![]() Also forgot to add, i just got home from the test drive. And its pretty awesome i must admit. I have been driving with a blocked fuel filter for weeks so all this power feels so new to me lol. Its like i've awoken some kind of beast.
21-11-2013, 11:31 PM
I must have missed that bit whys it not big enough? Suppose at 1 micron doubt you will run in to, to much trouble any way.
22-11-2013, 09:40 AM
Project "KEV"....boosted Mini | Piggy | 59 | 39,647 |
24-04-2018, 12:58 PM Last Post: Magenta Sunset |
| The boosted 205 rat - pictures and video added (25.09.16) | ginge191 | 134 | 111,969 |
21-04-2017, 10:46 AM Last Post: ginge191 |
