Threads: 136
I would either use plastic welding or fiberglass from the undeside to strengthen it and then use filler in the top.
81
My bumper has a big split in it from when i drove up a pavement. I used a spare rubbish soldering iron to remelt the grille back onto its tabs. With this though im not sure how you would fix it. If you cable tie it that will be a good fix as it will be strong and pull it together and if you do it in some funky colours it might look alright. To get it back to looking original though then maybe push it back together and remelt the underside with a soldering iron. then im afraid it may be filler and respray time but i doubt it will ever look the same!
Threads: 44
Car Model/Spec: 306 d turbo
18-12-2012, 07:54 PM
(This post was last modified: 18-12-2012, 08:00 PM by bayley.)
like ben said...take off the bumper and fibre glass the back,wet and dry and respray it and as for the black trim just wet and dry and spray it.simples!
o and i used matt black on all my grey trim but satin black is fine.
Threads: 141
35
or if your lazy and cant be bothered with trying to fix your bumper, just get a new one. although you might be waiting a while for another sigma ph1...
Threads: 18
Car Model/Spec: Ph1 Sigma DT
Yup thats the problem, the rest of the bodywork need sorting too and the chances of finding a completely mint sigma are slim to none, it will need some kind of touch up/spray so i may aswell repair this one get the car straight and get it painted
Threads: 13
Car Model/Spec: 1998 1.6 miami 5dr
parksy have words with teddy im sure he has ph1 bumpers which i can always paint cheap for you
