23-09-2013, 02:59 PM
Will the wishbones from a 1.4 petrol 1998 fit a 1999 HDI? I would like to recondition my spare pair first to keep downtime to a minimum. I know they can be a hassle from doing them on a 405.
Wishbone compatibility
23-09-2013, 03:00 PM
As far as i know.. the only difference between all 306 wishbones is whether or not the balljoint is 16 or 18mm
23-09-2013, 03:06 PM
as danny said they are universal across the rang apart from the ball joints.
and before you ask the only way to tell which ones you have for sure is to knock them out & look / messure. they are very parts bin special so their is no way to 100% tell
23-09-2013, 04:04 PM
they are also different between non pas and pas models
24-09-2013, 06:50 AM
but only the ball joint again not the actual arm itself
24-09-2013, 07:19 AM
^^^^^ yeah this.
the listing in the motorfactors books gives non PAS and PAS options....one being 18mm and the other 16mm. there is no other size/length differences. been there, got a tape measure and verniers and done that. this has been covered matt!!! (and to the newbie!) -thought I would get my usual not using search function dig in
24-09-2013, 08:02 AM
(24-09-2013, 07:19 AM)Piggy Wrote: ^^^^^ yeah this. yeah fair enough, some come with balljoints riveted on though so best to know unless you intend to grind them off
08-10-2013, 08:39 AM
balljoints do not just come in different size diameters they come in different lengths too. I know a chap that fitted a 1.4 16mm balljoint to his GTi6 that had 16mm balljoints and the wheel was cambered to hell as they were shorter (but this is probably due to pas/non-pas)
08-10-2013, 08:41 AM
I am curious to this also...as I have a bit too much camber on the front of mine
08-10-2013, 09:51 PM
Buy good ones, I;ve posted as have others what happens to the cheap versions
08-10-2013, 09:58 PM
the PAS ones have more camber. Non pas on a pas car is blatantly obvious by looking at the wheel as it looks like it has positive camber!
11-10-2013, 10:46 AM
Non PAS balljoints will give about 12 degrees of POSITIVE camber if you DO have PAS.
Trust me, I know lol As to measuring the balljoint, whip the wheel off and pull down the rubber boot, get some calieprs around the joint ant measure it, saves messing around removing the balljoint from the hub just to measure it
![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
25-11-2013, 08:48 PM
I got a pair of new wishbones with P-bushes and 16mm ball joints if they any use. I bought wrong ones lol.
| CV Boot compatibility | Cruiser Al | 4 | 4,373 |
12-06-2022, 11:13 AM Last Post: Toms306 |
| Eibach springs compatibility | Jimbo | 6 | 5,396 |
20-07-2014, 08:23 PM Last Post: Jimbo |
| Axle compatibility query | Mattinthehat | 13 | 8,725 |
06-07-2014, 12:48 PM Last Post: Frosty |
