Eibach springs compatibility
Right so im pretty fed up of running really low, and on the TA coilovers its hardly comfy. And its ruining underneath my scraping everywhere
So ive won some xsara vts shocks/springs cheap on ebay. Anyone ever ran these on a Dt?
Also if there not suitable im looking at same eibach springs. Obviously mostly rated for the gti6. As they'll be going on a dturbo does anyone know how they'll be as in height / ride comfort
Cheers james
[Image: av5ym8.jpg]
They will be fine for a DT. Engine weights are quite similar. Only thing is you may not get the full 30mm drop as they are designed to go with a shortened shock like the B8 but will be fine.
The eibach kit for gti6 and dt are the same.
(20-07-2014, 07:28 PM)Niall Wrote: They will be fine for a DT. Engine weights are quite similar. Only thing is you may not get the full 30mm drop as they are designed to go with a shortened shock like the B8 but will be fine.
Ok niall thanks, what about the vts struts im under the impression there slightly shorter than 6 ones as standard
[Image: av5ym8.jpg]
It will be fine mate Smile
(20-07-2014, 07:32 PM)ConorTRG Wrote: The eibach kit for gti6 and dt are the same.
This...
As for the Xsara VTS's, I have a set on the HDi atm, so roughly the same as DT tbh.
Does anyone know if the vts springs are lower than '6 ones??
[Image: av5ym8.jpg]
  CV Boot compatibility Cruiser Al 4 4,272 12-06-2022, 11:13 AM
Last Post: Toms306
  Eibach/B4 coils binding? wld 11 9,805 16-10-2016, 04:49 PM
Last Post: wld
  eibach 30mm springs Jimbo 12 7,265 01-09-2014, 05:49 PM
Last Post: MisterGTR
