fitted new pump now wont start :(
just finished putting the bosch pump on my car, and now wont start Sad i have been turning it over for ages with the injectors cracked but barely any fuel comes out when its turning over? could it be stop solenoid stuck? i have put a 12v feed from the battery to the solenoid and it makes a little clicking sound. Or could anyone give me any ideas what could be up?
Inside the pump could be rusty and not pumping.
Has it been sat around without diesel in it for any period of time?
[Image: av5ym8.jpg]
if you have some diesel at the injectors then you are doing better than I was last week...and then mine kicked into life!!
have you disconnected the glowplugs and not reconnected?
how much fuel is at injectors?
Crack the injectors and crank at full throttle, diesel should be shooting out of those buggers!
right i have got it running now only by turning the max fuel screw nearly all the way in, the pump was stored with diesel and is meant to have been rebuilt around 5000 miles ago with new seals and 11mm, but now it is really slow to rev and has no power at all, when i did the timing i locked the crank, cam and put the 2 bolts in the pump pulley so im deffo sure i have got the timing right
Squeeze the primer when you rev and see what happens.
Did you time the belt in this order
Crank,fuel pump, cam and water pump
In other words anti clock wise
This makes sure it tensions on correct side
[Image: av5ym8.jpg]
sounds rough. any air in the lines?
idle ok?!
i just put the belt on and then released the tensioner, does that make a difference then? and i have drove it for around 15 mins and didnt get any better so dont think there is air, and i tried sqeezing the primer and it didnt change anything
has the LDA been setup right...and you say fuel screw is ALL the way in??
how is the lever assembly setup?
Yeah can get timing out if not done in that order even if it was locked off
[Image: av5ym8.jpg]
even a tooth out wouldnt cause these issues though
No I agree with that but it will rule it out wont it.
Keep winding in the smoke screw see what happens
[Image: av5ym8.jpg]
(14-09-2013, 07:23 PM)Jimbo Wrote: No I agree with that but it will rule it out wont it.
the adjustment of retarding/advancing the pump is about two teeth! so a tooth wont cause this...especially with him locking all the pins in
shouldnt need much on the fuel screw to be hones.
my 11mm is in by about a turn and a half...and its giving the 2.1 PLENTY of fuel!!!!
(14-09-2013, 07:10 PM)Piggy Wrote: has the LDA been setup right...and you say fuel screw is ALL the way in??
How do I set up the LDA up properly? And i haven't changed anything just bolted the pump on and connected the throttle cable up. Yeah the screw has to basically be all the way in or it won't run or start, thanks for all the replies appreciate it
Sounds to me like you got the timing wrong.
http://www.youtube.com/watch?v=epUylG49qs0
Did you manually turn the engine over and re check the timing holes? That could be the issue.
How does it sound? If it sounds like a very loud transit it's probably timing or lots if white smoke. But it's it's just generally under powered its probably fuel starvation of some sort. Does it coal?
Stage 2 XUD Sedan
No I didn't re check I should off really, and no not 1 bit off smoke and engine sound nice and quiet
pics of pump to show setup be good I think.
no smoke/coaling but quiet engine sounds like no fuel.
if timing was out, with an 11mm it would still coal like hell
Make sure you have the inlet and outlet fuel banjo bolts in the right place, if you have the outlet banjo on the inlet line there will be a massive restriction as the outlet banjo only has a bleed hole in it, where as the inlet banjo bolt has a normal/large hole.
^^^^thats a very good call...
plus it just wont drag fuel from tank if its plumbed in wrong
Okay then thanks ill get some pictures and post them up
erm....
your throttle cable isnt connected to the throttle arm! lmao
try that!!!!! lmao
AND theres no spring under the throttle arm!!? Huh
and the max fuel screw is not even half way in! The warranty seal is still on it even!!!!
who fitted this??
Puggy306 wearing a blindfold while being attacked by bees?!
AND theres no wire on the stop solenoid...not sure how you even got it started!
The more I look the more silly things arent right with it!
Haha sorry I took these pics half way through putting the throttle arm back on, I was just seeing if it was adjusted properly
that boost compensator hose looks a little weird too.
(15-09-2013, 05:28 PM)Tonibruce Wrote: Haha sorry I took these pics half way through putting the throttle arm back on, I was just seeing if it was adjusted properly
that makes some of the pics a bit useless then really.
so IS there a throttle arm spring?
and where does it rest?
and is that how you have the max screw positioned at the moment?
Lets start again:
that waranty seal needs removing asap from the max fuel screw.
you need to wire in the stop solenoid...not sure how you even started it without it wiring in....I would hazard a guess that THIS IS YOUR ISSUE!
unless its different, the throttle arm spring is needed!
The return fuel pipe needs a hose clip as does the boost compensator pipe on the intercooler end of the pipe.
Right I have put it all back together now and ill get some proper pictures tomorrow for you, and there was a wire to the solenoid but I just removed it
That be cool...if you dont get any replies with new pics, PM me as I be busy this week. We'll figure it out Smile
PS get some pics of the wire you have going to the solenoid, the throttle position at idle, the max fuel screw too
  Cold start issue- fuel pump? Blaze Addict 3 3,696 20-01-2019, 11:10 AM
Last Post: Martin306
  Bosch pump years fitted Saloon306 10 5,427 24-06-2016, 10:27 AM
Last Post: Mattcheese31
  Car won't start, no fuel getting to pump karl2.0 6 4,294 23-12-2014, 02:23 PM
Last Post: pioneer DJ paddy
