Car won't start, no fuel getting to pump
So I bought a 306 D turbo
Owner had the fuel pump screwed out 'Lucas'
I took the green bung off, screwed it back to standard
then realised there is no fuel primer bulb in my engine bay
poured diesel into the fuel filter and cranked until the battery died
any ideas? thankyou
Check the in tank filter could be blocked up. Ive had that before.
Get yourself a primer bulb dude.
Can be had for not a lot of money from ebay, or local scrappy if you are desperate for one now.
If you get one second hand, check it for cracks as they can go a bit brittle over time.
                                             [Image: 2ljm03k.jpg]
        I Don't Have A 306.
I got a few if stuck ThumbsUp
may off wound the lucas fuel screw too far back in? you say u put it back to standard?
(23-12-2014, 09:44 AM)vincent1 Wrote: may off wound the lucas fuel screw too far back in? you say u put it back to standard?
Owner before me said he had it screwed out half a turn, thing was chucking too much smoke out the back on start up so I wound it back half a turn
On the line going from the filter to the pump there is no suction/diesel going through it, only the tiniest amount stuck between an air bubble, I took the fuel filter cap off and filled it with diesel still nothing
Where would I connect a primer bulb if I got one?
Were about in NI are u maybe could shout over and have a look for ya
  Bosch pump fuel screw broken Forby 0 3,266 12-03-2019, 06:47 PM
Last Post: Forby
  Cold start issue- fuel pump? Blaze Addict 3 4,052 20-01-2019, 11:10 AM
Last Post: Martin306
  Is immobiliser coded to fuel pump? Huddo 2 3,528 07-12-2018, 03:04 PM
Last Post: Ruan
