09-08-2013, 01:51 PM
Bigger blower on the cheap
09-08-2013, 06:35 PM
As others have said it's got to be a TD04. They are well known and they only have a few different models. The GT series units seem to have umpteen different configurations and for instance the one I have is a right hassle to adapt which means I am having to spend money on just getting the things changed which are obviously wrong for an XUD. You can probably get a TD04 on for £200 whereas with my GT20 it's looking more like £350 to give you a rough idea.
09-08-2013, 06:58 PM
(09-08-2013, 06:35 PM)306Puggy Wrote: As others have said it's got to be a TD04. They are well known and they only have a few different models. The GT series units seem to have umpteen different configurations and for instance the one I have is a right hassle to adapt which means I am having to spend money on just getting the things changed which are obviously wrong for an XUD. You can probably get a TD04 on for £200 whereas with my GT20 it's looking more like £350 to give you a rough idea. f*ck.. I think I spent about £700 getting mine on
09-08-2013, 07:11 PM
only coz you kept blowing them up pellowe!
my gt2056s has cost me about £30 in parts so far for a gearbox mounted situ Wishes for more power...
09-08-2013, 07:19 PM
£30 in parts...I know people exaggerate on this forum but that is a bit hard to believe. Even if you have drill, welder, tap and die set and everything else. An EGT probe costs £15. Oil line costs £15. That's £30 already before anything else.
10-08-2013, 09:41 AM
turbos are for fags....i'm fitting a leaf blower, Black and Decker big boy
10-08-2013, 08:48 PM
The merc turbo that con67 and mal fitted is probably the cheapest you could fit with so little f*cking about trying to get it fitted.
The way conor did it was to ream out (on a lathe - £30/40???) the hotside of a k14 to accommodate the bigger turbine wheel. Then the k14-2 just bolted up. No messing with the exhaust or adaptor plates. Its a really simple cost effective way of doing it. Turbo £50-80.... lathe work £20-40....Exhaust work £0.... Max £120. However, i always thought it was a shame to fit the big turbo and not create a bigger better flowing downpipe, but that is just my opinion. There isnt much difference between fitting a t25 or a td04. Both need adaptor plates for exhaust and manifold. I cant comment on the gt turbos or vnts other than to say they probably command a bigger price due to their newer tech.
11-08-2013, 08:41 AM
(10-08-2013, 08:48 PM)anto Wrote: The merc turbo that con67 and mal fitted is probably the cheapest you could fit with so little f*cking about trying to get it fitted.When I reemed my elbow and hotside it went much better and I was a sad I didnt just use the merc one and a massive down pipe, so your right!
11-08-2013, 02:18 PM
(11-08-2013, 08:41 AM)con67 Wrote:(10-08-2013, 08:48 PM)anto Wrote: The merc turbo that con67 and mal fitted is probably the cheapest you could fit with so little f*cking about trying to get it fitted.When I reemed my elbow and hotside it went much better and I was a sad I didnt just use the merc one and a massive down pipe, so your right! Alrite stranger hows the form? I still think it is one of the neatest ways to fit a big turbo on an xud. Even just fitting a bigger downpipe to the k14 hotside would work well, i just always hated the standard 306 elbow.
11-08-2013, 02:39 PM
(11-08-2013, 02:18 PM)anto Wrote:(11-08-2013, 08:41 AM)con67 Wrote:(10-08-2013, 08:48 PM)anto Wrote: The merc turbo that con67 and mal fitted is probably the cheapest you could fit with so little f*cking about trying to get it fitted.When I reemed my elbow and hotside it went much better and I was a sad I didnt just use the merc one and a massive down pipe, so your right! That's because the 306 elbow is wank for airflow, drops to about 1.5" at one point...
11-08-2013, 03:09 PM
(09-08-2013, 01:29 PM)silverzx Wrote:(09-08-2013, 01:25 PM)4WayDiablo Wrote: Mines been gov modded but most of the time there really is no need to hit 6k Mines has power til 6k, solid 25psi from around 3.5-4k. In answer to the thread question, TD04 would be easiest/cheapest as so many have done it.
12-08-2013, 08:59 AM
(11-08-2013, 02:18 PM)anto Wrote:Shes having another child here on tuesday, other than that all quiet!!!(11-08-2013, 08:41 AM)con67 Wrote:(10-08-2013, 08:48 PM)anto Wrote: The merc turbo that con67 and mal fitted is probably the cheapest you could fit with so little f*cking about trying to get it fitted.When I reemed my elbow and hotside it went much better and I was a sad I didnt just use the merc one and a massive down pipe, so your right! |
| Bigger turbo suggestions? Something handy found? | Logue1996 | 8 | 7,374 |
28-07-2017, 10:39 PM Last Post: Chris_90 |
| bigger turbo adapters | craig-dodd | 16 | 14,061 |
04-02-2017, 05:48 AM Last Post: Dave |
| Fitting bigger turbo shortly | Owen_G_ | 16 | 9,814 |
07-03-2015, 11:25 PM Last Post: Piggy |
![[Image: signature.png]](http://s22.postimg.org/cgh3ss11t/signature.png)
![[Image: signature_zps1a02ba79.jpg]](http://i1128.photobucket.com/albums/m481/martypellowe/signature_zps1a02ba79.jpg)
![[Image: Eq4gGTq.png]](http://i.imgur.com/Eq4gGTq.png)
