Xantia inlet gasket
Should there be a gasket on a xantia inlet manifold where the elbow bit goes on for the pipe work. This is where I'm on about
[Image: null_zpsb9322a89.jpg]
I would think so....
if not, flange sealant??
You no there is you looked at mine. metal to metal wont seal 20 psi plus will it ...
Just sand both sides down smoothly with some 400 grit on a sanding block. Then it will seal.
(19-06-2013, 02:58 PM)306Puggy Wrote: Just sand both sides down smoothly with some 400 grit on a sanding block. Then it will seal.
lmao
lmao
lmao x2
Absolute tool!
lmao
lmao x2
lmao x3
i just used some flange sealant for mine bud, holds fine at 25psi
No just a rubber o ring. Avec la....
[Image: Image2547_zps43c71a3c.jpg]
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
He has a metal elbow so does not have the o ring
Cut one out of cereal box lol? Bit of blue hylomar, job jobbed :p
I can vouch for a bit of gasket paper (cereal box) Smile
(20-06-2013, 04:57 PM)Jimbo Wrote: He has a metal elbow so does not have the o ring
I have one with a metal elbow too, must check it when I have time and see what it has Wink
  Fitting Xantia Inlet Nathan1305 7 4,823 10-04-2015, 12:13 PM
Last Post: Nathan1305
  Xantia manifold gasket Nathan1305 2 3,129 06-04-2015, 07:57 AM
  Inlet Manifold Gasket ally406 6 4,494 11-11-2013, 10:37 AM
Last Post: ally406
