Cully's Bianca 6 R150 YVM
looks good paul, needs the pug badge back on the fannymould, its looks a bit plan without it
i do have the badge but left it in work Wink
Looks clinical ha
deffinetly brightens up the engine bay nicely Smile doing the same to the engine covers
(27-05-2013, 08:18 PM)sam Wrote: deffinetly brightens up the engine bay nicely Smile doing the same to the engine covers
This
Best buy yourself a good duster lol
Looks fresh pre-driven though Wink
[Image: siggy1.jpg]
"serpentine belt".
God you ARE old! Rofl
thumbs up for carparts4less and euro car part
all my bits turned up today weds not bad at all considering they were ordered on sat night of a bankholiday
idler pulley is fitted car sounds a lot better
i have a nice new clutch and crank seal that needs fitting Big Grin
thanks to Dum-Dum i now have some wishbones with excellent bushes,
they had 18mm balljoints but as there the wrong size for mine i had to drill out the rivets so i can fit my new 16mm joints ive just fitted to the car for MOT
coat of black hammerite now so fitting is saturdays job
You're welcome
oh yeh sorry connor thanks for collecting them for me Wink
Tongue and thankyou for the CIDER!!! Will let you now how it goes down
whishbones are fitted also found the anti roll bar clamp not fitted correctly it wernt located into the chassis
so sorted that went for a spin
Big Grin im smiling again
cars so much better it turns in quicker with the new wishbones, deffo pulls better with a cleaned airfilter and the revs dont stick so alls good now thats sorted too
also the clutch is booked in for next saturday Smile
at the moment im attacking some rust on the gutter above the drivers door,
so get that undercontrol before theres a hole in the roof
dremmel with a wire brush some kurust and some paint will sort that as its under the gutter rubber
decided to have a go at the Battery terminal as it was a bodge!
cut off the terminal recrimped a new lug and heat sleaved it and a new clamp
pritty!
and the inlet is still clean! Big Grin
I think bodge is an understatement for the battery clamp how it was
clutch is Done what a shit of a job
thanks go's to Dum-Dum for some advice over the phone, or we would have been scratching our heads for a long while on how to disengauge the fork arm from the bearing
oil seal was replaced it looks as if the leak was from the sump though as the bolts were loose all cleaned up and refitted
dont want to do one of them again for a while!
clutch plate was well worn and the pressure plate was falling apart!
clutch is light and bits hard now!
How are you liking a working clutch then haha
went and washed the car at the local jet wash......and
the widscreen wipers dont work! goto like the reliable french electrics
so stripped out the wiper motor stripped it down cleaned all the bearings brushes and contacts, reasembled and all works again
think it needs replacing soon looks rough inside and the brushes are low Sad
some new bits turned up today
will go and fit them in a bit and do away with the cable ties holding the old ones on Smile
this week ends project has just arrived in a box
new set of rear beam mounts should go nice with a recon beam Smile
Ooooer your cars getting the works! Definately a good save. Did you think about solid rear mounts or not interested/too much wonga for how much you use the car?
yes tom exactly that too much money for what they are for the amount of use/ abuse they would get.
all the latest stuff ive bought like gear linkages,rear mounts,oil,filters,gearbox oil, have not cost me anything as the airbag resistor sales are paying for the parts, ive just got to fit them Smile
Sad car!
(18-06-2013, 10:31 AM)cully Wrote: airbag resistor sales are paying for the parts, ive just got to fit them Smile
And the great thing is.. a slight tweak of the eBay ad and you can claim they gain 10bhp too Smile
some quick pointers for changing the beam mounts
jack up car support car on the propper jack points to avoid damage
use penetrating oil on all bolts your going to slacken/remove
undo bolts while axle is mounted firm but dont remove bolts
slacken but dont remove
slacken but dont remove oposite side
remove top fixing bolts slowly lower side on jack caution watch brake lines!!
part remove lower bolt, fully remove top bolt
mount should wiggle out by tipping to the rear of the car
remove mount note offset
admire the used mounts
refit in the oposite manner
near side needs bottom damper bolt removing to let the arm swing lower to let bottom mouunt bolt out
only part remove lower bolt same as other side remove top bolt lower beam on jack caution watch brake lines!
refit new mount
admire your handy work
while the wheels were off i took the rear arch liners out to have a peak and replace the chewed up one,
i was pleasantly surprised to fined no rust!
so have wire brushed the Arch's out and given it a good couple of coats of Hamerite white once thats dried i will refit the new arch liners
so list of things done to date in no order
front ball joints x2
front Brake flexys x2
front wishbones X2
steering gator
handbrake cable
O/s front wheel bearing
new cam-belt kit inc water pump
new aux belt idler
new clutch
new comp gear linkages
re-con rear beam
beam mount set x4
replaced radiator
inlet manifold clean/paint
fixed Hatch C/L
fixed N/s C/L
refitted door cards re glued fabric
repaired cigarette lighter
replaced rear lights
removed air con condenser
fitted A/c fan switch Mod
painted rear Arch's
renewed rear arch liners
sourced Boot carpet & hatch shelf
Things left to do......
clean Paint front arches
replace front arch liners
degrease and steam clean engine bay
You've sure done a lot to get her back to a good condition!
A/c switch mod
it turns the A/c button in the car to a cooling fan overide switch it brings on the fans at full speed
How.
disconnect the a/c compressor
unplug the pressure switch on the refrigerant line
bridge pins 1-3 in switch loom plug
Good job there mate, Wish I had the time to do all that.
now ive got all the suspension joints and bush's done Ive booked up for a wheel alignment for Wednesday so will be driving it into the big city to go to work the its off to the alignment after work at 330 should get a printout of all the angles Big Grin
  cully's XU10J4RS cully 11 10,230 30-06-2016, 12:53 PM
Last Post: welshpug
  Cully's Electric car ..T project cully 144 98,145 16-04-2016, 04:14 PM
Last Post: cully
Users browsing this thread: 11 Guest(s)
