Sam's low boost supercharged rallye
Ok well day 1 was so mad with bits not fitting, not right parts in oil cooler was a right piss about.so we staeted with the oil cooler decided to go with a 16 row cooler as I have heard 13's aren't up to it.
So got the kit unpacked pipes where miles to long can't cut them because of the stupid ends so had to get the cable tires out Smile
It was also a bloody good job I didn't have a gti6 twin fan setup or we would of been completely f*cked.we out out the second fan suround and mount it they.also replace the oil filter at the same time.
[Image: 20130523_115256.jpg]
Sitting just to the side of the number plate
[Image: 20130523_184651.jpg]
Engine looking very sorry for itself, no battery either Blush
[Image: 20130523_115250.jpg]
So we relocated the battery behind passengers seat
[Image: 20130523_184401.jpg]
Rocker covers on and fc coil pack also sanded back cylinder head and autosoled it
[Image: 20130523_151034.jpg]
[Image: Cn91r40h.jpg]
Looks good chap! With regards to moving the battery did you just extend from or did you do all the live and earth points in the bay?
[Image: SDC10442-1.jpg]
(25-05-2013, 02:06 PM)Jonny b Wrote: Looks good chap! With regards to moving the battery did you just extend from or did you do all the live and earth points in the bay?
Cheers johhy I got some earths with the swampy kit I link on to a bolt on the battery box plate and we ran one (not the earth) into the fuse box.i can get pictures for you if you want my main problem was we had was we had no terminals at my mate garage so had to burn one of a old cable.
So got the cover on and manifold and re worked the induction kit with lots of cable tires Smile also relocated the ecu box and cable tired that to the back of the engine bay then we had to adjust the strut brace as it didn't quite clear the brake fluid reservoir.
[Image: 20130523_184501.jpg]
[Image: 20130523_184446.jpg]
[Image: 20130523_184513.jpg]
Got to paint the side of the block at the weekend and slam panel.
Day 2 BRAKES !!!
[Image: 20130524_092146.jpg]
They clear...just.bloody close mind Smile
[Image: 20130524_132231.jpg]
[Image: 20130524_132259.jpg]
Then lowered the back and replaced broken shocks the ta ones are literally haf the size of the oe ones so no more bumpy ride.
After it settled
[Image: 20130525_123857.jpg]
[Image: 20130525_123909.jpg]
Then we started on the seats pig of a job.side mounts did nt fit so had to basically cut new holes and de drilled the base mounts quite cleverly so base mounted seats still fit
[Image: 20130525_124018.jpg]
[Image: 20130525_123955.jpg]
[Image: 20130525_124002.jpg]
[Image: 20130525_124052.jpg]
Getting chuffed with them so comfortable, love long journeys now Smile
yesss! Brilliant stuff! Cant wait to have a ride in this at pugfest. Cant wait to see it tomorrow too!
(25-05-2013, 08:35 PM)SRowell Wrote: yesss! Brilliant stuff! Cant wait to have a ride in this at pugfest. Cant wait to see it tomorrow too!
Yeah see you tomorrow mate, you should hear me first though Dodgy
You've got the kid in a candy shop syndrome! Lol.
Much more left to get?
Now only a has been!!
www.autorite-sport.co.uk
Couple of pics would be good chap!
(26-05-2013, 07:50 AM)Tallguy_2 Wrote: You've got the kid in a candy shop syndrome! Lol.
Not to much now was going to get a jetex cat back this week but got to do the bloody cam belt instead Undecided
Aero catches do on then and maybe lower the front abit see how the rear settle's over the comming days
Dropped the old buckets off a mr rowell today and had a little go on NFS underground 2, god thatvgame brings back some good memories Smile
Got this picture this morning I got 50 like already on Facebook so thought it was worth showing
[Image: 20130526_122622.jpg]
So started today painting up bits in the engine bay.
I used a vht paint, stupidly I did have the job then relised I was useing matt black instead of gloss Confused but thought I do it then see if it grounds on me .
At work we have a seam cleaner so may give that a shot aswell
Before I started .
[Image: 20130531_133803.jpg]
[Image: 20130531_133759.jpg]
So did throttle body, cylinder head pas pump engine mount.
[Image: 20130531_155840.jpg]
[Image: 20130531_160405.jpg]
Shame with matt goes nt really do it justice but its alot better, think I ll do the cylinder head front bit as the polishing ant going as planned Doh
Then I started on my spare wheel holder as I removed the original one
[Image: 20130531_153527.jpg]
Haven't bolted anything in place yet though its a £3 replacement metal tabel leg from homebase and with a foam insert to stop the movement its great also got a strap the tire it down for good measure.
Still to do is painting slam panel and clean all the crap of the abs unit or blank it off with a plastic cover
This has soooo much win dude glad to see it on a black rallye to Smile
Awesome! Cant wait to get started on my car now! Big Grin
(31-05-2013, 10:52 PM)SRowell Wrote: Awesome! Cant wait to get started on my car now! Big Grin
What one Dodgy
(31-05-2013, 10:19 PM)sam Wrote: This has soooo much win dude glad to see it on a black rallye to Smile
Cheers mate I booked a track day at Snetterton next monday and my track time for fcs today so actaully using it for what I built it for
Sam how much was fitting for the cage?
306 HDI, soon to be XUD
(01-06-2013, 01:01 AM)declantg Wrote: Sam how much was fitting for the cage?
Me and carl did it he welded in the 'x' for £150
Was nt to hard to do apart from the the arch with the pertol pipe in is abit fiddly
May paint it again not shure yet.
Adding some padding today, ordered it as RED but looks kinda pink.
[Image: 20130605_200954.jpg]
[Image: 20130605_200936.jpg]
Door card fail
[Image: 20130605_201101.jpg]
[Image: 20130605_201055.jpg]
So need to do some modding friday Smile
New wheel spacer, tested greifly after and I'm in love think I can add 10mph to each bend
[Image: 20130605_201928.jpg]
Before
[Image: 20130605_201500.jpg]
After
[Image: 20130605_213215.jpg]
Quick releases pretty quick aswell
[Image: 20130605_212713.jpg]
I bet its a right effort to use your indicators or wipers lol
Yeah it's but weird, I had a dish wheel previously so was nt to bad.abit of a mission if your holding onto the wheel at the same time.
I got to do cambelt and aero catches tomorrow then doing a trackday will sam monday Smile
I got that padding in mine!! Give it a couple of weeks and it'll be proper pink bud ha ha!! Looking good though fella!! What track you doing?
Doing Snetterton on Monday the 300 circuit.Be great to finally put it through is paces and try not to brake it before pugfest/FCS.
So we did the cambelt, pulleys and catches today . fitted a rich w bottom pulley and a few carl cambers cambelt pulleys, now its sounds sweet as a nut.could nt believe how light the pulley was Smile
Mm shiny....
[Image: 20130609_144557.jpg]
[Image: 20130609_163310.jpg]
Rubbish picture of other shines
[Image: 20130608_101822.jpg]
Final got round to putting the omp centre on
[Image: 20130608_101725-1.jpg]
Aero's now bitch of a job to do a 'never again one'
[Image: 20130609_162006.jpg]
Put the track wheels on ready for tomorrow
[Image: 20130608_102114.jpg]
[Image: 20130608_102035.jpg]
No centers #becauseracecar
[Image: 20130609_144628.jpg]
[Image: 20130608_101645.jpg]
Got my fcs ticket and track time
[Image: FB_IMG_13706211207923535.jpg]
Clean the car ready for morning with the girlfriend useing some questionable product but still think it looked ok
[Image: 20130609_163713.jpg]
[Image: 20130609_163554.jpg]
[Image: 20130609_163719.jpg]
looking super sweet....shame I guna miss FCS.
(09-06-2013, 07:03 PM)Piggy Wrote: looking super sweet....shame I guna miss FCS.
Cheers mate Smile I'll be a pugfest aswell
My next purchase will be quite expensive so no more shinies for a while Sad
I'm away at pugfest, was at prescott hill the other weekend though, great place.
At CC, is it REALLY a true open pit for two hours??
From what they making out yes as im on 10:15-12-15 I could be in the first session but they will be the 'off' here and they which will probably cut the session short.I have pugfest 2 weeks before which is always epic so aslong as I don't bin the car a combe its a win Smile
see you tomorrow for epic fun at snetterton!
Cars looking amazing! Are you doing snetterton tomorrow evening? I'm coming along to watch Dan in the RX8. Wouldn't mind asking you a few things about your car if I get a chance, I'm hopefully getting a track rallye/gti in the next few weeks.
[Image: 20120704_212316.jpg]
(09-06-2013, 08:55 PM)Ben Wrote: Cars looking amazing! Are you doing snetterton tomorrow evening? I'm coming along to watch Dan in the RX8. Wouldn't mind asking you a few things about your car if I get a chance, I'm hopefully getting a track rallye/gti in the next few weeks.
Yeah no problems,be great to see more of you guys from here. hopefully have a trouble free outing, have never driven Snetterton before either so will be a great learning curve and to see how far I can push it Big Grin
you really need a phase 3 boot, the strip looks so out of place on a smooth lid
  Supercharged 306 Rallye Gunge 18 12,487 16-12-2011, 03:27 PM
Last Post: Gunge
