ball joint failure symptoms
Star
What are the symptoms if a ball joint failing?
2000 2.0 HDi Estate
knocking clonking from the front
less responsive delayed steering
car wandering around the road
uneven tyre wear is another good indicator
hmmm this could me my problem, how do you test it?
[Image: 20gh7o0.jpg]
(19-05-2013, 08:47 PM)rd070707 Wrote: hmmm this could me my problem, how do you test it?
Jack it up and see if there is any play up and down in the wheel.. Smile
Blaze '6 and Blaze D-turbo!
By up and down do you mean hold top and bottom and shake to feel for play?
Yea try pushing the top while pulling the bottom and vice versa if you feel play then get em changed
Team Doesn't own a 306
^What danny said Smile
you may find as well that the hub may become f*cked. thats whats happened to mine and it sounds and feels terrible at the moment Sad
I get a knocking but no play in the wheel when tested as above. Seems to knock at lower speeds more so. I've already changed the drop links.
2000 2.0 HDi Estate
P bush checked those?
  Ball joint/ Hub to strut pinch bolts Uberderv 7 5,552 04-01-2018, 11:40 AM
Last Post: Mighty306
  fitting a front suspension ball joint impotentials 3 3,845 29-10-2016, 05:46 PM
Last Post: Poodle
  Bottom ball joint sizes Xsikid 4 3,691 04-05-2016, 05:45 AM
Last Post: Paul_13
