hub repair replace?
hub repair replace?
Putting my wheel back on today and when doing the wheel nuts back up 1 has stripped, when taking wheel nuts off to begin with they were well tight,
Wheel nuts fine must be hub,
Is it a easy fix or a replacement?
Get a tap and and clean the threads out
try and get a tap/thread restorer through it. If that doesnt fix it, you could try drilling it out and helicoiling it but i really wouldn't on a wheel bolt. Its a half hour job to change a hub.
Ok will try, s/h hub or new 1 if needed, guess new be pricey
New one will need a new wheel bearing as well, the hub and carrier and 2 separate parts. You could as a temp use a Timesert which is as good as a normal thread and can be used over and over unlike helicoils
Anybody know what size tap i need? Got a couple at work i can borrow
Cheer s
M12 x 1.25mm
What side was it? I have a hub with the abs sensor still in if you're interested.
Driver side rear
Ah nevermind, I've only got drivers side front.
All tapped out and fixed, thanks for the help
  Do I need to replace my 13" spare wheel? cheapo 4 2,477 11-12-2015, 08:45 PM
Last Post: Jonny81191
