Do I need to replace my 13" spare wheel?
Got a 155/80/13 spare !
Lucky I haven't lost it as it leaves the carrier loose under the car !! Although the spare's clamp/hooky/thread thingybob actually bottoms out and traps the hook against the carrier and shouldn't let it drop. I've been hearing a noise over bad bumps, but thought it was prolly the rear silencer, which is ALSO the wrong size and finishes 4 inches before it reaches the bumper. I saw that the spare's tread was ok when I bought the car but have only just seen the size of the tire when I was sorting the brakes this week. It does fit over the rear disc, I tried it, but haven't tried it on the front yet. It's probably going to snag the front caliper, and although the overall diameter is a match for the 185/60, I'm dubious about the offset being correct too.
Dammit, can't even post in the wanted section yet!  Rofl
WoW! That was cheap!  Inlove
It won't fit the front I don't think, got a million 14" steels here if u want one lol
^ what he said, won't go on the front. But the benefit of a 306 is you can jack it up at the front and get both front and rear wheels off the floor, then just stick the spare on the rear and the rear on the front (assuming you had a front puncture)
To stop the knocking, you could always stick a bit of wood above the wheel against the boot floor.
(11-12-2015, 03:15 AM)Mattcheese31 Wrote: It won't fit the front I don't think, got a million 14" steels here if u want one lol
Oooooo! Rollin on steelies eh? Now you got me thinkin!!! Got any rusty ones. Wink they'll suit The Scratcher best. I might be in touch after xmas, if there's any money left.
(11-12-2015, 07:49 AM)Jonny81191 Wrote: ^ what he said, won't go on the front. But the benefit of a 306 is you can jack it up at the front and get both front and rear wheels off the floor, then just stick the spare on the rear and the rear on the front (assuming you had a front puncture)
Yeap, the weight of the HDI should balance it nicely! Wood it is then!  Big Grin
Bit of 3x2 about 12 inches long should do the trick.. ThumbsUp
  Spare wheel on a Rallye... Ben_w 4 2,728 23-06-2015, 11:36 AM
Last Post: Ben_w
  Spare wheel Niall 14 6,201 17-07-2013, 07:58 PM
Last Post: Niall
  hub repair replace? sqweeky 10 5,588 20-05-2013, 10:24 PM
Last Post: sqweeky
