Threads: 138
72
Car Model/Spec: Mincebus
Righto guys
I'm needing to replace my discs. Now I've always thought discs are irrelevant to a large extent, as anything less than a few hundred quid would ultimately warp and crack anyway...
So my last 2 sets of brembo discs (@£80 or so a pair) have cracked and warped over the ~10k I've used each set.
I'm slightly questioning the point of spending that on another set when I can buy a pair of Pagid discs for £37ish off ecp, with probably the same result eventually!
Does anyone have any info/opinions on other discs. I dont necesssarily mind spending more if they don't die so quickly!
Cheers in advance
Astor 'X' 4 GTi6-
6 - SOLD!
Threads: 202
58
Standard mintex ones. As you say, either that or go spend lots and lots on really decent ones.
Threads: 178
28
Car Model/Spec: HDi!
Ive always been told to treat the disks as the expendable part and get decent pads...
cheap disks and decent pads (Y)
Threads: 30
Car Model/Spec: 01 HDI Estate
I've got Pagid discs and pads all round and so far am pretty pleased with them, they've been on about 4-5k and no problems at all, need to replace the rears again soon but that's due to the calipers being seized on and cooking the discs and pads but got new calipers and although they were thoroughly cooked they haven't warped or anything I just want to replace them for my own peace of mind and to make sure they wear more evenly.
Threads: 78
49
I've got the boggo Mintex ones all round on mine (have done for about a year, since its' MOT) and can't fault them. Although I won't be anywhere near as hard on them as you...
Pagid. Very cheap with forum discount and they are very good for a budget brake!
Threads: 136
I rate the mintex pads and discs. I replaced the first set because they were warped but they lasted long enough for the price of them.
Threads: 138
72
Righto, I'll be getting the Pagid ones it seems! Cheers all
Astor 'X' 4 GTi6-
6 - SOLD!
Threads: 56
19
Car Model/Spec: Moonstone HDi
Mintex and pagid are virtually the same iirc.
Threads: 208
60
Given 5 thank(s) in 5 post(s)
not really what 100% relevent to topic. but..... iv got budget drilled and grooved from (will link late) and iv given them loads of stick over the last 2 1/2 years on both gti's with no warp / cracking and minimal lipping. i think they are epic for the money.
not really rating brembo these days. i used to get brembos from GSF £18 quid a side so cheapo ones and they would struggle to do 5k of commuting with a little ragging on the weekends and that was on a Dt with a OE MC
Threads: 48
Pagid
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 186
38
Car Model/Spec: MG ZR VVC
For the rears though would Eicher be alright you think for general day use?
Threads: 48
But CP4L have codes.....
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
