1 clunk when accelerating, and 1 when braking
Stop filling JP's thread full of shite you two Smile
[Image: J5hxCcC.jpg]
Right, balljoint replaced, noise still persists... grrr.
Guess I'll have to take the wishbone right out tomorrow and have a look there.
JP
JP
Dosnt sound suspension related to me, more chassis / subframe /engine line. something is shunting forth and aft but is fairly tight
[Image: sigi-2.png]
Have you checked the gearbox or engine mounts
I have checked the engine mounts yes, though I didn't think it was them as it'd also clunk once when braking with the clutch in (no reverse torque on engine).
Darren, I've checked the subframe, all tight - I'm starting to run out of things to tighten... Bloody car.
JP
JP
Let me know when you've figured out what this is so I can fix the same fecking problem with mine. It's absolutely doing my head in!
Are you sure its not your turbo whacking the bulkhead on acceleration?
/troll
306 HDI, soon to be XUD
Fixed.
Took total wishbone setup both sides totally apart and put it back together again. No idea what it was!
JP
JP
ahhhh....love it when its fixed...pure joy.
well done.
(08-03-2013, 10:52 PM)jammapic Wrote: Fixed.
JP
ninja
Admit it.. i was right
Well I didn't replace anything... just took it all to bits to inspect.
JP
mines had same noises since i got it 3 years ago;
i got used to the odd noises whenever i was in traffic going to/from work, but recently it started to twitch going around corners at low speeds ? its had 3 mot tests and i have had a crowbar on rear bushes but they seemed ok. i had no work on yesterday so spent a day on my own car for a change---- i fitted 2 new rear p-bushes and its a different car !! no more clonking when rocking steering wheel (i was convinced noise was in the rack) and no more clunks when tapping the brake pedal and it steers properly now. just got to get it in work onto 4 wheel aligner to make sure alls well.
I had some loud clonking noises on mine everytime I went on or off the loud pedal. It turned out to be the offside engine mount had cracked on the body itself and was allowing the whole engine/ mount to shift and move about. Stripped it all apart and welded it back together with reinforcements ;-)
  Braking on and off MY95 20 9,328 19-03-2015, 10:20 PM
Last Post: MY95
  clunk knocking sound Whodafunk 28 13,611 07-01-2014, 11:49 AM
Last Post: Whodafunk
  clunk when turning rd070707 8 4,978 15-07-2013, 05:46 PM
Last Post: RePT
