Penetrating oil
Penetrating oil
What penetrating oil do you guys use?
I've used plus gas but I don't find it too good and I've heard good things about Q10. Has anyone here used this stuff?
Inb4Samass/giggidy
I use 3-in-1 Smile
I like plus gas tbh.
Is 3-in-1 not a little too thick to work as a penetrating fluid?
There are a few different ones though, the orange one is penetrating spray.
http://www.halfords.com/webapp/wcs/store...yId_255223
Plusgas.
As the thread that was just up about this, Plus Gas. Can't fault it.
Yeah, another plus gas vote, bit, the 3 in 1 stuff is pretty good, but plus gas is better I find
If it's something you know is going to be trouble, soak it in advance to give it a chance to work Smile
(03-03-2013, 09:54 PM)Scott Wrote: There are a few different ones though, the orange one is penetrating spray.
Oops thought you meant the multi purpose oil.
(03-03-2013, 10:04 PM)Curt Wrote: If it's something you know is going to be trouble, soak it in advance to give it a chance to work Smile
Very true, planning ahead and all that.
Plusgas.
/thread
I normally make the offending item hot with a blowtorch. Then spray it with whatever I have lying around, usually wd40 or gt85 while it's still hot. Seems to do the trick.
Plus gas & 3in1 (orange can)
Elbow grease works well for me Wink
Team Doesn't own a 306
a bit of spit gets things moving for me
[Image: mcetg0.png]
KY jelly does the trick when I'm penetrating
Official Team Go-NAD fan club
I heard using sand helps?
I mean those VTEC boys can't be wrong.
Double TT
half price of wd40...twice as good
Astraglide
/thread
Users browsing this thread: 12 Guest(s)
