Turbo actuator
Turbo actuator
Hi,
I was wondering if any people have had any problems or know of any problems with the actuator not letting the turbo boost properly?
They can get weaker after years of use, and can creep under load as the exhaust gases overcome the spring force on the wastegate.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
So I take it that will mean less boost as the pressure will leak through the wastegate?
think mine is the same as can hear it some times and then i wont
(24-01-2013, 10:21 PM)DeeTurbo Wrote: So I take it that will mean less boost as the pressure will leak through the wastegate?
Yeah.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Sort of, some of the exhaust gasses are allowed to bypass the turbine, so some of the energy that would be used to create boost is wasted.
roll on the 2nd feb at ray west to see if we can find out whats up with mine
What are your symptoms?
can only hear the turbo some times same as the actuator spowling, so one moment will be fine then it wont
When the car does this does it smoke because of the lack of boost?
nope no smoke
  Wastegate actuator DeeTurbo 1 2,214 17-11-2016, 06:55 PM
Last Post: Poodle
  Actuator pipe size Jtrigga 3 2,712 10-08-2014, 11:34 PM
Last Post: mcglynn
  Lazy/slow actuator or wastegate? JJtheHITMAN 22 9,203 11-11-2013, 10:46 PM
Last Post: JJtheHITMAN
