Lambda Sensor
Morning Chaps,
need to get this one sorted out fairly pronto as my existing lambda is buggered to the point of having to run with it unplugged...
http://www.lambdasensor.co.uk/main/ntkpr...OZA527-E17
http://www.ebay.co.uk/itm/NGK-Front-Lamb...231fbd3751
Are these the correct sensors? Should I buy the one from Ebay, or does anyone get a sweet discount on them elsewhere that I can take advantage of in return for cuddles and/or a cheeky bum?
Just get a Bosch one. Should be cheap from Ecp with the discount code.
ecp dont have any for my car though; checked this morning on the interwebbzz?
Hunt for a genuine one though, i'd never trust pattern lambdas after previous experience
clicky
Are NTK not genuine?? I thought they were??
Nah Bosch are the genuine ones iirc
Any ideas what the difference between these Lambdas are?
(Bosch Part numbers)
0258003717
0258003716
I don't trust ECP as far as I can throw them; they've said the part number is 0258003716, but I don't trust the Scot either, who says it's 0258003717...
Different wire lengths iirc. Early GTi's had a longer wire than the later ones. But couldn't tell you the difference from the part numbers. There were definitely two different wire lengths though.
http://www.lambdasensor.com/main/bosch/p...0258003716
http://www.lambdasensor.com/main/bosch/p...0258003717
That seems to correspond on the basis of the above links, I was just a bit put off as when I just ebayed that bosch part number it came out with lambdas for smaller engines for the 306 (1.1, 1.6, 1.8, and some 106's, including 1.4 & 1.6 engines). Just didn't want to get one to the wrong spec, and I just know how tragic ECP are at getting the right parts in first time...
lmao f*ck off that seems to correspond, i DO have useful gti6 info you muppet
I just prefer to troll first
  GTi 6 Lambda Fault Toms306 24 12,851 30-04-2016, 06:09 PM
Last Post: Toms306
  lambda sensor willJspears 5 3,073 02-04-2014, 08:55 PM
Last Post: eddy_gti6
  Lambda sensor location Daniel306 3 3,012 18-12-2013, 04:00 PM
Last Post: Daniel306
