locking wheel nuts
Does anyone have any tips on removing locking wheel nuts without the key I have the good old socket and hammer but not enough room between rim and nut any suggestions woul be great
Do you no the make of them? Might be worth trying to find the replacement socket otherwise it will be a pig of a job
306 HDI, soon to be XUD
if its the ones with splines on the side, try smash a 19mm socket (or whatever is just to small) onto it
You could try a gator grip socket (wish i had the money for a set of these)
http://www.ebay.co.uk/itm/Gator-Grip-ET ... _500wt_949
Or a locking wheel nut removal tool/socket
http://www.ebay.co.uk/itm/SCARFELL-7-PI ... _523wt_698
Them gator grip things are fecking useless, my bud who runs a tyre place, got a set first time he used it all the splines bent and fell out got a replacement that lasted 3 uses so just got his money back. Best bet is get something welded to it
[Image: SDC10442-1.jpg]
Chisel and a large hammer
Thans for the advice recently bought a stick welder never gived it a thought just hope the weld will hold it enough to crack the nuts off
My local garage will do them for 25quid a wheel f*ck that :o
17mm socket and a huge hammer
[Image: redranger.jpg]
25 quid robbing gets got mine drilled out for a tenner
Locking wheel nut remover kit from snapon
Im with jonny, those sockets are complete wank on anything done up more than finger tight, try welding something on the end, will be your best bet
  Locking wheel nut key.....f@c# you, you bar steward. turkish 30 16,386 02-04-2014, 08:29 PM
Last Post: SupaStar88
  F**King locking Wheel nuts :@ Chris_90 18 10,925 28-08-2012, 11:24 PM
Last Post: Chris_90
  help with choosing locking wheel nuts kingy 20 10,063 06-06-2012, 08:09 AM
Last Post: kentiiboii
