Turbo Sedan
Turbo Sedan
Always fancied a Sedan so when one came up cheap it would have been rude not to save it.
Cue 1 Sedan with a knackered engine:
Has sucked up water and was running very badly. Smoking all colours under the sun
Then Cue 1 battered Hatch with a great engine but tatty inside and out:
Removed dead engine and put it into the Hatch ready for scrap and spare parts:
Good engine getting ready for TD04, Fmic and 11mm pump all waiting
Also got coilovers and new pads ect to go on and some refurbed wishbones ect but thats for a later post.
Heads ready to get looked at and a good degrease and clean of the waterways are in much need by the looks!
[Image: IMGP1382-1.jpg]
[Image: IMGP1383-1.jpg]
[Image: IMGP1430-1.jpg]
[Image: IMGP1374-1.jpg]
[Image: IMGP1431-1.jpg]
[Image: IMGP1432-1.jpg]
[Image: IMGP1394-1.jpg]
[Image: IMGP1396-1.jpg]
[Image: IMGP1397-1.jpg]
[Image: IMGP1424-1.jpg]
[Image: IMGP1425-1.jpg]
[Image: IMGP1422-1.jpg]
And finally how it stands with the temp new engine Tongue
[Image: IMGP1429-1.jpg]
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Awsome lil project dude. Wots the blower like on the temp engine rofl Big Grin
Abit too much lag for me personally tbh TongueP
Blaze 1.6 Dead
haha typical mel!
www.prestige-auto-care.co.uk
Hahaha win Big Grin
Should be good when your done mate, that Sedan looked pretty clean when I saw it! Give me a shout if you need a hand, I owe you a beer for that rad Wink
Nice to see another Sedan on the forum.
Thanks always loved sedans. Especially lowered. I was hoping to get one when I got the Estate but were none around locally
Got the head checked over, a slight skim and 2 bent valves replaced also stem seals done, got gaskets and bolts so just needs refitting which I will do next weekend as I have afew weddings coming up so pump change this friday then head back on next once I have give the pistons and waterways a clean out
Blaze 1.6 Dead
I can't find a sedan anywhere! Sad and that temp engine looks nice Wink
Engines almost ready to refit had new HG, Valves, Cambelt, TD04 going on, FMIC manifold, 11mm gov modded and ground LDA Bosch setup.
[Image: IMGP1505.jpg]
Had the subframe seam welded just to give some strength back as i am going to cut the bulkhead back just to make sure i have no issues with the turbo once it's in. (pics to follow)
Cleaned all the rust and shit from the enginebay and gave it afew coats undercoat just to clean it up really and some high temp paint for along the back(might have some before pics as it was driven tho fords and streams daily so had suffered abit.
[Image: IMGP1530.jpg]
[Image: IMGP1529.jpg]
Just setting the coilovers up on 306 topmounts tonight and the wishbones will have there new bushes in shortly. New wheel bearings and TRE both sides also.
Subframe will be refitted tomorrow along with undersealing of the front wheelarches, back will be done at some point also.
Blaze 1.6 Dead
looks like you got a good layer on there kyle give me a shout when engines going in
Will do hoping to have it in soon, Just need to get a new topmount and that bottom one done and it can go in then, minus a gearbox anyway i am going to get some discs and cut the bulkhead to paint it tomorrow. Ye about 3 coats but to use the last of the tin as i needed a brush cleaning tin Lol
Blaze 1.6 Dead
Turbo and fanimold on:
[Image: IMGP1569.jpg]
Engine in and gearbox follow:
[Image: IMGP1580.jpg]
Had to Dewastegate the TD04 as even with the bulkhead ground out it still pressed into it but luckily my plate press just against the flap arm so it "should" not open. If so only by a small amount which i can live with.
Afew clearance issues to sort. Whats the best way around this? Anyone route the top pipe differently or make up there own?
[Image: IMGP1589.jpg]
[Image: IMGP1588.jpg]
Oh also fitted a new sump gasket and painted the sump altho now its all scratched :glare:
[Image: IMGP1552.jpg]
Blaze 1.6 Dead
OMG, Ph2 sedan, im jealous.
I almost bought a ph2 but it was green and the draw of another bianca and a bosch pump was just too much
Been waiting for you to update this, looking good fella.
That turbo pipe is supposed to go through the inlet manifold, like up between the 1st and 2nd runners and then out the drivers side.
Edit, on the fourth photo you can actually see where the pipe rubs slightly on the 1st runner when it's routed properly :-)
I asked afew people that have xantia manifolds they said it goes round the side. I did try squeeze it tho but it was tight
Blaze 1.6 Dead
(13-11-2012, 05:50 PM)HDIkyle Wrote: I asked afew people that have xantia manifolds they said it goes round the side. I did try squeeze it tho but it was tight
they will fit through the mani like stock iirc you need to take a grinder and shave abit of the support then clock the turbo around more and it will fit easy Smile
Afew things done, radiator, uprated top and gearbox mounts, gear rods, suspensions all on, driveshafts ect just waiting for my brake lines to come and new pads and discs can go on. Ordering some pipe to start cooler this week Smile
[Image: IMGP1606.jpg]
[Image: IMGP1603.jpg]
[Image: IMGP1602.jpg]
[Image: IMGP1623.jpg]
[Image: IMGP1624.jpg]
Intercooler might be moved over more to the middle will see whats best for fixing it on and cutting for pipes
And i know the hose is squashed on the manifold but with a pipe and clamp on it should be fine as that all moves together so no worries or rubbing
Blaze 1.6 Dead
Cooler might be better turned 90 degrees clockwise so the pipes go down the side of the radiator? Bit tight getting them over the top.
[Image: 20120704_212316.jpg]
Cant believe your putting a ph1 front end on this. Ruined.
Phase 1 is the best. Outside anyway. Wanted to keep a phase 2 dash. And naa going to cut the slam panel the pipes will go straight over the top, that was the idea to start with
Blaze 1.6 Dead
Intercooler fitted, pipes fitting when i get some clamps and a beader:
[Image: IMG00719-20121230-1611.jpg]
[Image: IMG00717-20121230-1604.jpg]
[Image: IMG00716-20121230-1604.jpg]
Green braided front hoses:
[Image: 536186_10152376111525392_2076617035_n.jpg]
Calipers painted up:
[Image: IMGP1676.jpg]
Some dirty parts become clean:
[Image: IMGP1725.jpg]
[Image: IMGP1726.jpg]
Some rust sorted :/
[Image: IMGP1708.jpg]
[Image: IMGP1705.jpg]
[Image: IMGP1714.jpg]
Along with some new Brembo pads, Oil pressure and Temp gauges
Blaze 1.6 Dead
[Image: IMGP1752.jpg]
[Image: IMGP1745.jpg]
[Image: IMGP1739.jpg]
Also removed the liners and undersealed the offside arches today, hoovers and scrubbed then painted as abit of rust was showing around the seatbelt points on one side
Blaze 1.6 Dead
Got MOT tomorrow so should pass i hope.
Fitted amps and speakers:
[Image: IMAG0042_zps46c838f9.jpg]
[Image: IMAG0064_zpscad16e44.jpg]
Bumpers and lights all looks pretty sweet now its together:
[Image: IMAG0060_zpsa1afc2ac.jpg]
Painted the headlining and all the grey trims also fitted black cabby sunvisors:
[Image: IMAG0079_zps4c4ed666.jpg]
[Image: IMAG0080_zpsee36bbf3.jpg]
Needs lowering on the rear but 1 of the bars wouldnt come out also the suspension is rock solid no bounce whatsoever so that needs some attention also:
[Image: IMAG0011_zps6d148d81.jpg]
[Image: IMAG0010_zpsdeea3f8c.jpg]
Blaze 1.6 Dead
You've missed a hell of a lot out Kyle!
(02-01-2013, 11:12 PM)HDIkyle Wrote: Intercooler fitted, pipes fitting when i get some clamps and a beader:
Some rust sorted :/
ha ha the above the door looks the same on my car...held together by prayers lol
[Image: siggy1.jpg]
That interior is maaad!
(12-05-2013, 01:38 PM)Tom Wrote: That interior is maaad!
Tbh the car is quite tame for Kyle atm!
Did it pass the mot?
Bye Bye D-Turbo
  306 d turbo sedan - RFM 81 rfm81 10 6,943 09-04-2016, 01:50 PM
Last Post: rfm81
  Peugeot 306 Sedan D-Turbo - ROMANIA SonnyRoby 150 131,707 13-03-2015, 03:37 PM
Last Post: Matt
  D turbo sedan project johnnytsa 22 22,650 07-01-2013, 01:02 PM
Last Post: johnnytsa
