13-07-2012, 05:55 PM
Planning just a head change, aswell as cambelt etc obviously. In two weeks time
book it off guys
book it off guys
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg)
Matts rallye project. operation derust
book it off guys
13-07-2012, 06:52 PM
Ill help if im off, defo easiest just to throw eds spare engine in. If ed wants to rebuild one let him rebuild yours.
13-07-2012, 06:54 PM
I think Ed wants to keep his spare because cambelt.
That's a right shitter mate, honestly can't believe it's actually snapped the belt? What sort of rpm were you doing? And you said it carried on running after...if there's no belt how did that happen?
13-07-2012, 07:37 PM
The belt originally shredded, and the car stalled, I then started it again thinking it had just stalled, revved it to get it going and made things worse. I havent seen the belt yet, tbh it might not be snapped. But tbh it really didn't sound right.
Horrible noises = new head. I'm not taking any chances lol ![]() TEAM CONROD SHITTING RALLYE!
13-07-2012, 07:40 PM
Ah okay, maybe I misread your post. I'm guessing you must have been going fairly slowly when it stalled though?
Tbh for peace of mind I'd be tempted to go and have a look to check what's happened.
13-07-2012, 07:53 PM
Yeah will take alook tomorrow. At work tonight but off tomorrow.
Was doing sub 30mph on a corner about to stop at a junction ![]() TEAM CONROD SHITTING RALLYE!
13-07-2012, 09:09 PM
If you got it re started it cant of snapped the belt.
13-07-2012, 09:30 PM
Sounds like it may have just shreaded the belt abit if you are lucky new cambelt kit and all will be good
13-07-2012, 09:39 PM
It wouldnt of snapped. More than likely shredded and stretched or slipped a tooth or two.
Well will Inspect it all tommorow. Getting a new head anyway as it was a good price. So will replace it as wanted to do the headgasket anyway, if my heads all good then I'll just sell my head onto someone. ( I know ginge wants one
)(13-07-2012, 09:39 PM)Niall Wrote: It wouldnt of snapped. More than likely shredded and stretched or slipped a tooth or two. If it slipped a tooth it would have bent valves anyway no? ![]() TEAM CONROD SHITTING RALLYE!
13-07-2012, 09:49 PM
Not necessarily...the exhaust timing was out on my old GTi-6 (only found out when I saw the new owner at Pugfest!) and that was okay, it just wasn't as quick as it should have been. Actually, thinking about it now, maybe a dodgy cambelt fitting was actually the cause of you not being able to pull away from Sam's arse?
13-07-2012, 09:51 PM
![]() The fact that it still ran near the end makes me think you may get away with just putting a belt on... As if it didn't let go properly and just slipped then they may have not had a coming together...
13-07-2012, 09:53 PM
That could well have been the issue. I did think about it when I spoke to curt last. I thinking just to be on the safe side sticking a new head on anyway. Wouldnt want to fit the new cambelt and find I've got a tapper!
13-07-2012, 10:00 PM
(13-07-2012, 09:49 PM)Scott Wrote: Actually, thinking about it now, maybe a dodgy cambelt fitting was actually the cause of you not being able to pull away from Sam's arse? my arse has it's own gravitational pull. due to being awesome. true story. on a related note, id have tought if its slipped a bit, ie more than a tooth, thered have been contact. timimg can still be flexible, to a few degrees, even tho there is very little clearance in these engines Member of the 99% warning or you're nothing club
13-07-2012, 10:04 PM
I thought the valves stupidly minimal amount of play and thus slipping one or two teeth would cause an instant death of the valves?
13-07-2012, 10:06 PM
yeah, my post was bable to be honest, basically, i think one tooth is fine, but anymore and id have thought there'd be issues.
it may have been that your timing was out a little bit anyway, and then if the belt slipped some more, taptapdingding. Member of the 99% warning or you're nothing club
13-07-2012, 10:10 PM
Exactly and I really don't want my engine to sound like eds
Normally I'd be inclined to agree 100%. Only thing that gives it more hope IMO is that it was still running after the "incident".
Oh dear god no, no-one wants an engine that sounds like Ed's! It's like being under machine gun fire
13-07-2012, 10:13 PM
It did sound horrendous though. And kinda affected the steering? Guessing powersteering cutting in and out with the aux belt douching about
13-07-2012, 10:15 PM
yeah if the steering was f*cking about, then the aux belt will have been, thus affecting power to the
PAS pump. Member of the 99% warning or you're nothing club
13-07-2012, 10:19 PM
When your engine taps so hard you can't turn...That's when you know it's bad.
13-07-2012, 10:23 PM
(13-07-2012, 10:19 PM)Scott Wrote: When your engine taps so hard you can't turn...That's when you know it's bad.
14-07-2012, 10:23 AM
14-07-2012, 11:29 AM
Right just spoke to rich w and he can supply everything I need for 310
That's a lynx mls head gasket and bolts Oem cambelt kit Waterpump And a alloy crank pulley ![]() I don't think that's a bad price. I means it's 100 more than what I guess would normally cost but the alloy Pully is £90 anyway.... ![]() TEAM CONROD SHITTING RALLYE!
14-07-2012, 11:30 AM
presume thats just parts?
14-07-2012, 11:33 AM
Yeah just parts. Tbh I tempted to find my own hg
HG & bolt set - £120 Alloy crank pulley - £87.50 OEM Day timing belt kit - £75.00 Water pump £50 Hg is a mls one from lynx ![]() TEAM CONROD SHITTING RALLYE!
14-07-2012, 11:36 AM
doesnt seem too bad to be fair....
when we bolting it all up then
14-07-2012, 11:40 AM
damn. i'll be showing two aussie birds around london that day...
Member of the 99% warning or you're nothing club |
| 306 rallye trackday project | twangy | 383 | 333,939 |
19-03-2020, 05:12 PM Last Post: Eeyore |
| Matts cheap cherry rallye | Matt-Rallye | 15 | 14,022 |
02-01-2018, 08:45 AM Last Post: Matt-Rallye |
| Matts Cherry HDi Dturbo. Project Stage 1+ & tidy up. | Matt-Rallye | 29 | 25,242 |
10-05-2017, 12:49 PM Last Post: Poodle |
