Threads: 448
51
Bein weird, high bitting point, and if you drive normally, then put your foot down, it revs like a bitch instead of gaining any speed. The once it's reached around 6k the car kinda feels like it remembers what a throttle peddle is :/
What the f*ck is it?
Threads: 289
92
Car Model/Spec: Phase 17 R26
Threads: 448
51
Haha yes, and before anyone says it, it's a Clio haha
Threads: 171
46
Threads: 4
Car Model/Spec: Clio 182
i would say that was your clutch slipping, when was the clutch last done?, get a new clutch and new pressure plate an thrust bearing, cant really tell with out actully being there but at a guess i would say that,
Threads: 289
92
Has Fooby been driving it? If so then it's definitely the clutch.
Threads: 448
51
A slipping clutch? How much will that cost to fix? It's a 1.2 16v :/
Threads: 289
92
I reckon we could do it ourselves (with Curt's help  if he's free) so you'd only need the parts! Could try giving GSF a call, or Midnight Motors in Wembley (0208 9033388) as if you're doing it at Curt's I can go pick it up and meet you there.
Threads: 448
51
Sounds like fun. I'll ask curt of he's up so it,
It's a bitch to drive, trying to get it to go anywhere, you boot it and it goes no where
Threads: 13
Car Model/Spec: 306 Rallye // Saab 9-3 Aero.
Just drop the box of yourself, it aint that hard!
Threads: 541
124
Defo sounds like a slipping clutch, clutches for those should be pretty cheap but petrol and matches would be cheaper
Threads: 448
51
Realised last night while driving it that it's in every gear, you have to build up gradual speed rev it too about 2k in each gear and it fine, once it goes past 2k or putting foot down it goes nuts!
Threads: 82
27
All that insane low down torque making it slip mate!
Threads: 448
51
Haha obvisously. Although in seriousness I though clutch slip was down to big power!
Threads: 82
27
Matt Wrote:Haha obvisously. Although in seriousness I though clutch slip was down to big power!
Or female drivers...
Threads: 13
Any car can have a slipping clutch if the friction material has been suitably glazed (from riding the clutch etc) or just through wear and tear.
Threads: 9
19
Or a worn out/abused clutch
Threads: 448
51
It was quite a high bitting point when we got it, and very stiff. I thought it needed a new clutch anyway lol just never experience this myself
Threads: 92
43
Or the crank seal could be starting to leak, is it loosing any oil?
It's a Clio. It's shit!
Nah clutch is definitely slipping. Chances are its worn out (being at the hands of a women driver *awaits abuse*) but do check for leaky crank seal or dodgy clutch cable (don't think the clios are hydraulic are they?)
Threads: 180
21
Car Model/Spec: Broken Phase 2 GTi6
Scott Wrote:Has Fooby been driving it? If so then it's definitely the clutch.
wtaf
you're couch
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
Threads: 289
92
Following on from Facebook grammar policing:
You're = you are. I am not a couch.
Threads: 92
43
Threads: 9
19
Scott Wrote:Following on from Facebook grammar policing:
ROFL
Threads: 13
Leaky crank seal rairly causes a clutch to slip as engine oil is expelled fairly quickly by the heat. Gear oil, now thats a different story.
Threads: 24
Car Model/Spec: 530i Sport/306 Rallye
Have fun getting the driveshafts out - IIRC they've got little locking pins where they go into the gearbox
Black 306 Rallye
Topaz Blue E39 530i Sport
Nordic Green 406 1.9TD
