Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
Anyone recommend decent engine mounts.
Looking to replace two upper mounts by eBay has sweet FA.
Or anyone got any upgraded mounts they want shifting?
Phaes 1 GTI 6 - Onyx Black
Threads: 376
38
18-06-2014, 05:53 PM
(This post was last modified: 18-06-2014, 05:57 PM by ginge191.)
Will have a look into those mate, cheers!
Looked at Baker bm and they do a whole kit for £88,
Not too shabby!
Threads: 183
20
I got baker bm top mount and gear box mount with a powerflex lower mount! Couldn't recommend them enough!
I have a baker bm lower mount but not fitted yet as it needs to be pressed in but the powerflex just slides in with a little lube!
Threads: 58
Car Model/Spec: Loads
Always use Vibra now without any issue's, the top one has a larger surface than the std type too which helps engine movement but really for a road car a uprated lower one is all you need with new OE top mounts as the engine is just supported by those, really the engine needs another mount the gearbox side
Threads: 465
114
Car Model/Spec: Vauxhall
as miles says vibra tec lower and std tops with a chocked engine cradle steddied mine no end its a joy to drive now
