Engine mounts - HELP!
Think my engine mounts are on their way out, symptoms are; knocking at low speed (thought this was ball joints and antiroll bar bushes, changed them and problem still occurs), there's lots of movement in the gear stick when in gear and any speed (vibrates considerably), knocking when changing gear which I thought could possibly be clutch but unsure and I can feel vibrations through the accelerator pedal at 40mph+
any help would be appreciated guys!
1.9 diesel Phase 2 - scrapped
1.8 meridian Phase 3 - going strong!
get a bar in by the side of the mount and give it a lever, you should be able to tell . .Smile
i have a similar problem, i will check the engine mount drivers side also..
check for worn driveshafts too, see if there is any play in them - can cause the gearstick to bounce around
Anyone get to the bottom of this? ...Doubt he'll be back
(12-05-2015, 08:24 PM)highwayman306 Wrote: Anyone get to the bottom of this? ...Doubt he'll be back
He was online 9hrs ago Tongue
(20-04-2014, 10:54 AM)zx_volcane Wrote: check for worn driveshafts too, see if there is any play in them - can cause the gearstick to bounce around
I suggest checking this.
I had similar problem, I changed every engine mount as well.
  Engine mounts mackat 0 1,609 25-11-2014, 09:50 PM
Last Post: mackat
  Engine mounts ginge191 5 3,422 18-06-2014, 09:49 PM
Last Post: cully
  engine mounts ripp444 3 2,411 29-03-2014, 10:57 PM
Last Post: miles
