Threads: 18
Car Model/Spec: Phase 1 Sigma Blue 306 Dturbo
Hi all,
now im no expert on engines so i need a little advice my car seems to be burninga lot of oil when i bought it (end of september 11) it was up to the max on the dipstick but i checked last week and was alarmed to see ot was below the minimum so i went to the local garage (whom im sure is only still in busy cause of me lol) and filled it up i did ask him if this was normal and he said for D-turbos of that age it was but now im not so sure :?
any ideas??
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
few simple checks pal ...
- got any leaks - usually around the rocker cover?
- secondly, change your filter and oil
- thirdly, are you smoking on boost? - any oil in the intercool, quite simple to check, you may have a small amount from over the year wear but a lot 'running' out of the pipes is a worry
but yeh, the derv's do burn a fair bit
Phaes 1 GTI 6 - Onyx Black
Threads: 171
46
Its there quite a puff of smoke on startup? Could be stem seals on the way
Threads: 18
there is mate yeah that an expensive job??
Threads: 171
46
Yeah you would have to take the head off and have it practically rebuilt. I wouldnt say its a dont drive it another inch problem but best to get it done soonish
Threads: 18
cheers will have it looked at
Threads: 24
Shouldn't be burning any oil at all bud. My Dturbo is on 150K and the level on the dipstick literally doesn't move between changes and that is with a slight leak on the sump and out of the cylinder head cover.
