Quick one, After a set of steels for a 206cc. By any chance, are they the same offset as 306 ones?
Threads: 115
26
Car Model/Spec: 306
no they are a different et if i remember i think its 10 or 15mm spacers to get 206 wheels on a 306 at the correct et
Threads: 78
49
As above it's not, but should be fine as it all it means is they'll stick out an extra 13mm (ish). As standard they probably sit into the arch a fair bit as 306's
Threads: 208
60
Given 5 thank(s) in 5 post(s)
As curt says not the same but do fit, it prob will actually sit in the arch better than an OE 206 one, I.E it shouldnt look so set in
Fair enough. No worries. Sure i can pick up a set of 206 steels cheap. Its just i know where i can get a set of 306 steels even cheaper lol
Threads: 208
60
Get your spare from the 1.8 and test fit
(01-11-2012, 08:38 PM)puglove Wrote: Get your spare from the 1.8 and test fit
Would if i still had it!
Threads: 208
60
Try grants spare then lol
