206 wheels - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: 206 wheels (/showthread.php?tid=7585) |
206 wheels - Niall - 01-11-2012 Quick one, After a set of steels for a 206cc. By any chance, are they the same offset as 306 ones? RE: 206 wheels - spike2002 - 01-11-2012 no they are a different et if i remember i think its 10 or 15mm spacers to get 206 wheels on a 306 at the correct et RE: 206 wheels - Curt - 01-11-2012 As above it's not, but should be fine as it all it means is they'll stick out an extra 13mm (ish). As standard they probably sit into the arch a fair bit as 306's RE: 206 wheels - puglove - 01-11-2012 As curt says not the same but do fit, it prob will actually sit in the arch better than an OE 206 one, I.E it shouldnt look so set in RE: 206 wheels - Niall - 01-11-2012 Fair enough. No worries. Sure i can pick up a set of 206 steels cheap. Its just i know where i can get a set of 306 steels even cheaper lol RE: 206 wheels - puglove - 01-11-2012 Get your spare from the 1.8 and test fit RE: 206 wheels - Niall - 01-11-2012 (01-11-2012, 08:38 PM)puglove Wrote: Get your spare from the 1.8 and test fit Would if i still had it! RE: 206 wheels - puglove - 02-11-2012 Try grants spare then lol |
