11-10-2012, 04:07 AM
That's odd Cully, because a lot of the ones i work with won't let me connect if i try in the first few seconds, i usually have to leave the ignition on and restart the global scan after a minute or so.
Clarke OBDII Fault Code Reader
11-10-2012, 09:13 AM
(11-10-2012, 04:07 AM)Poodle Wrote: That's odd Cully, because a lot of the ones i work with won't let me connect if i try in the first few seconds, i usually have to leave the ignition on and restart the global scan after a minute or so. maybe its different between different ecu codes (in talking about the elm here not the PP)
11-10-2012, 10:44 AM
Aaaaaah thatll be the difference.
| Peugeot Fault code | Welshy_Pete | 8 | 5,338 |
09-08-2017, 08:09 AM Last Post: Poodle |
| Glow plug fault code? | JTaylor2005 | 2 | 2,667 |
22-05-2016, 12:22 PM Last Post: JTaylor2005 |
| Ecu reader with map on it to delete lights | MIKE-FORD | 0 | 1,849 |
05-04-2014, 10:20 PM Last Post: MIKE-FORD |
