bosch pump timing
Hi. How many lockiing points is there in a bosch pulley? Can't get timing belt on after a pump change from lucas?
2 locking points mate, 1 @ 12 o'clock 1 @ 4 o'clock
HDi Cabby Project Click
Cheers pal! Couldn't get timming belt on after a pump change!
Is the tensioner in its slackest position and locked there. Make sure you put the belt on in this order: water pump, crank idler, pump, cam then tensioner last. This way all the slack is at the tensioner making it easier to get on and less likely for the timing to be out when you have finished.
Thanks got sorted!
No probs, the rep button is the little + under my sig! ninja
  Slack in bosch pump? dt_ 14 12,291 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,602 05-01-2020, 09:09 PM
Last Post: jamie182
  Lucas pump timing probe issues weka 0 2,881 21-03-2019, 08:39 PM
Last Post: weka
