steering wheel movement up and down
as above i can move the steering wheel up and down and want it fixing. is this a steering colum mount?. if so is it easy to change?. cheers karl
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
sure you havent moved the locking lever?
under the cowling in a hole there is a lever to lock up and down movement
here is a pic of the cowl upside down , in the hole in the top left of the pic is the locking lever
can need a good push/tug to operate
[Image: %24(KGrHqR,!jgE4E+o(IeVBOHrRhFwig~~0_35.JPG]
If not, on the back of the locking mechanism is a nut (13mm iirc) which you can adjust to tighten up how hard the lever clamps the column in place.
its not the lever ive checked that. if i hold the wheel at 6 oclock i can move it slightly up and down. i will get a video tomorrow
Ph3 perv cab heaven
Black ph1 XUD died
Take the coweling off and have a look. Do they have bearings or anything of the like? I will look on the estate tomorrow
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
There are 4 nuts which hold the rack on make sure they are tight. Take the cowling and fuse cover off too see them
I've got this as well, I should really check it out...
guna check it tomorrw
Ph3 perv cab heaven
Black ph1 XUD died
Let me know how you get on Wink
There is a nylon bush, but if it worn like mine it wont move any more that about 1mm. anymore than that then its what already been said
ok cheers for that. ill text you liam if i sort it Smile
Ph3 perv cab heaven
Black ph1 XUD died
yeah that nylon bush can wear and cause play. I personally wouldn't worry..
think its an MOT fail !
had a fail for my old sierra for it
i was told its a fail too but it passed the last MOT like that
Ph3 perv cab heaven
Black ph1 XUD died
Mine has an advisory for it I think...
  steering wheel not straight after beam change/new tyres Iaitoo 16 8,166 13-06-2016, 05:58 AM
  had my tracking done again today , and my steering wheel isnt straight jjenn20 22 11,185 10-04-2015, 07:15 AM
Last Post: welshpug
  Changing rear beam/ Steering wheel problem E_KEL95 3 2,754 13-11-2014, 09:18 AM
Last Post: Toms306
