Head bolts
hi all, recently took my head off my d turb to be sent off for skimming, wandering what the correct size of the head bolts are to see if they are stretched, can someone tell me the measurements so i can check? or is it just worth putting a new set in? thanks.
Unless your going to be running silly boost id just go for some from local motor factors bud they should give you sizes etc
[Image: J5hxCcC.jpg]
Personally I would just fit a new set as a matter of course, I don't think they are expensive?
this reminds me, ive got a set of forged head bolts i need to fit Smile
It gives you measurements in the haynes manual and gives you the tolerance at which you should change them.
[Image: 20120704_212316.jpg]
  APR head bolts sam 13 8,158 17-04-2013, 12:57 PM
Last Post: Pompey306mark
