Aftermarket tacho and shift light
I've listed tachos in the thread title too as the effect is the same, but i'm only interested in the shift light bit.
Firstly.. do XUD alternators have a W terminal or will I need to open it up and splice one of the internal wires?
Secondly, is there going to be a way to use a shift light alone based on the W terminal output?
Basically I want a shift light, but don't want to have to buy an aftermarket tacho to get one working. If needs be i'll buy a tacho and cut the light off/extend the wiring and hide the tacho somewhere behind the dash. But that's a faff compared to just wiring in a shift light.
I don't need to calibrate a tacho to RPM as I have a working one in the car, what I need is a way of adjusting a shift light so I can set when it comes on...
  Wiring tacho from scratch... Need help!!!! Sfin01 0 2,381 27-08-2018, 09:29 PM
Last Post: Sfin01
  Help/Advice needed for Wiring in 205 STDT Tacho Counter silverzx 11 12,044 24-06-2013, 08:44 PM
Last Post: ozonehostile
  Tacho doesn't like heat. Toby 5 4,702 26-01-2012, 07:51 PM
Last Post: Daniel306
