bosch diesel injectors...
Tongue
...er so...are the N/A bosch diesel XUD injectors the same as the turbo ones??.
Different break pressures iirc mate
HDi Cabby Project Click
Bosch NA ones are tiny compared to TD's. Size does matter.
Stage 2 XUD Sedan
ah lovely...as I wondered...I assumed break pressures was the differing factor...didnt realise size was too
Not much in it admittedly, IDI injector nozzles don't change a massive amount... And as posted, they're 155bar vs 175bar for Turbos...
that break pressue is in the spring/tip isnt it...so if I was, speaking theorecticaly, to change the tips/springs for bosch 3.1s then the break pressure wouldnt matter?!
ah...but size is different?!?!
The nozzle is different as is the spring/shim stack...
You cannot just place the springs out of another injector in as they're matched, they require the pressures setting correctly with shims, which you won't have.
okeydoke. as I thought. thanks for confirmation.
swapping nozzles only.. Smile
Errrr....
Can't go mixing and matching nozzles, which was kinda the point of my post...
Change the entire injector as a unit unless you're sending them off to get re-shimmed and calibrated...
Be aware that if one nozzle is out of calibration as far as pop pressure goes, it will affect the injection timing...
Basically - get Turbo 175bar injectors... Don't try and change the nozzles yourself, or you'll end up with 4 injectors of differing break pressures, screwing up the overall timing of the engine.
Do a James and run one lucas like a boss
haha...fair play...I know one guy has done it with great success so shall enquire how...
thanks
(25-12-2012, 10:39 AM)Piggy1987 Wrote: haha...fair play...I know one guy has done it with great success so shall enquire how...
thanks
"Great Success"...
What you mean it runs?
Honestly, unless you have a pop tester and a Bosch shim set, don't even bother, you'll just end up with f*cked injectors...
nah thats fair comment...I have emailed him to find out...he is on this forum...blue ph1 on speedlines.
close to 170bhp and 250 torques on a nice smooth map so he must have set them up right
You can quite easily get that with dodgy injectors, it's the damage it's doing to the engine and precombustion chambers I'd be concerned about...
defo me too...will do me digging and see what I get
How will this do damage? Other than sound horrendous if there too soon or smoke like buggery if too late?
Big Grin Bosch injectors Niki 12 8,408 22-07-2017, 12:20 PM
Last Post: Niki
  Are KCA 17S42 Bosch injectors rated at 175bar ok for my modified XUD? 399road 4 3,473 11-04-2017, 03:33 PM
Last Post: 399road
  1.9 Bosch injectors Leeblair98 2 2,453 27-04-2016, 09:39 AM
Last Post: pioneer DJ paddy
