Bosch injectors
Big Grin
Hi everyone
Im new on here if this is posted in the wrong place sorry about that.
So i have an 306 xud and im doing a bosch pump conversion and have sum issues with injectors i bought what was suppost to be a full kit but got the wrong injectors (lucus)
After doing sum researching on part numbers i found a set,they came and they have 130 bar on them and i know xud9 ones should be 175 bar,the problem i have is no matter what i find on part numbers they all say 130 bar.
Could someone please shed sum light on this please?
Thanks in advanced
they'll be the Lucas ones mate i think Smile
(21-07-2017, 07:33 PM)Mattcheese31 Wrote: they'll be the Lucas ones mate i think Smile
Thanks for the reply.
I bought bosch ones tho dude the part number is KCA17S42 the person i bought them off said they came from a dturbo engine code is xud9te.
both types were fitted to that engine though mate, as you rightly say the Bosch ones break at 175 Smile
Yeah i know that both bosch and lucus was fitted to xuds im converting to bosch from lucus and need to know how you know the injectors are 175 bar? Huh
only bosch fitted to turbo models have 175 bar injectors.
It says 175 on the actual injectors Smile
There are bosch ones for the straight diesels i think that are 130bar break pressure. If you really are struggling to find some i may have a set.
(22-07-2017, 06:43 AM)Frosty Wrote: There are bosch ones for the straight diesels i think that are 130bar break pressure. If you really are struggling to find some i may have a set.
Thanks for your help xud people  ThumbsUp
Frosty if you have a set i would be really interested in them would rather get them on here rather than say ebay as i know there what im after.
 How much you want for them?
post a picture of the pump, if the injectors are wrong and came from the same engine....
(22-07-2017, 09:51 AM)welshpug Wrote: post a picture of the pump, if the injectors are wrong and came from the same engine....
Will post a pic in a sec,when i brought the bosch pump,lines and injectors they said it all came from the same lump but when i got the items the injectors was lucus not bosch,i think someone had swapped pumps and not injectors and ran a bosch pump and lucus injectors.
the issue i have is all bosch injectors are KCA17S42.
So i bought a second set of Bosch KCA17S42 to match the bosch pump i had,they came and have KCA17S42 130 bar stamped on them.
Is there two types of bosch injectors but with the same part number and diffrent break pressures?
I'll check I got some and let you know
(22-07-2017, 12:13 PM)Frosty Wrote: I'll check I got some and let you know
Thanks dude much appreciated  ThumbsUp
  Are KCA 17S42 Bosch injectors rated at 175bar ok for my modified XUD? 399road 4 3,681 11-04-2017, 03:33 PM
Last Post: 399road
  1.9 Bosch injectors Leeblair98 2 2,613 27-04-2016, 09:39 AM
Last Post: pioneer DJ paddy
  Storing Bosch Injectors Marcus1991 7 5,567 18-12-2013, 06:49 PM
Last Post: Martin306
