FAO coilover users
Fitted my coilovers but the leg only goes about half way down maybe a touch more into the hub doe to the locating stub been welded to the outside. There originally off a 206 so not sure if this is the reason or it will be ok.
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Grind the fucker off and drop it further down and just wack a nob of weld on higher up so it cant drop any more simples
There on now so can't get a welder in but there stainless arnt they so can't weld it to steel?
They hold rock solid still with the but tightened
Blaze 1.6 Dead
You can weld steel to it but the weld will be brittle and obviously it'll rust.
The problem is, welding to a casing full of oil...
ive heard this is the case with these but I know of couple guys who have run them 20/30k miles no issues
  Coilover protection lolsteve 6 3,769 09-01-2015, 10:22 PM
Last Post: lolsteve
  gaz coilover rebuild cost lolsteve 9 5,844 04-11-2014, 08:52 AM
Last Post: lolsteve
  TA Technix coilover topmounts toyo16 2 2,679 28-05-2014, 05:23 PM
Last Post: bashbarnard
